◆ MotionHoldUserMaskGet()
int32_t MotionHoldUserMaskGet ( )
MotionHoldUserMaskGet gets the Mask which will be bitwise ANDed with the value at the User Address.
The bitmask
Motion: Hold
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Definition rsi.h:6515
Set the motion hold type.
Definition rsienums.h:617
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
MotionHoldUserMaskSet()
