◆ Get() [2/2]
MotionController * Get ( int32_t controllerIndex)
static
Description: Get a MotionController object. This will NOT start the RMP firmware if it is not already running.
It will open and map in the existing firmware if it is running.
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
controllerIndexThe index of the controller to get (future multiple MotionController support). Default is 0.
CreationParametersGet
