◆ RecorderRecordDataDoubleGet()
double RecorderRecordDataDoubleGet ( int32_t recorderNumber,
int32_t recordIndex,
int32_t dataIndex )
RecorderRecordDataDoubleGet gets one double value from a retrieved record.
recorderNumberIndex of the recorder. 0 to (MotionController::RecorderCountMaximum - 1) valid.
recordIndexIndex of the collected Record. 0 to 1023 Valid
dataIndexIndex of the recorded double within that record. 0 to Number of Items collected - 1 Valid.
the double value from the indexed data.
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12981
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
RecorderRecordDataRetrieveBulk
