Represents the RMP soft motion controller. This class provides an interface to general controller configuration, firmware upload/download, network, user limits and data recording. To make a MotionController object, use MotionController creation methods.. More...
Static Functions
static MotionController * Create (CreationParameters *creationParameters)
static MotionController * Get (int32_t controllerIndex=CreationParameters::ControllerIndexDefault)
static MotionController * Get (const char *const nodeName)
 [Windows] Get an already running RMP EtherCAT controller by its INtime node name.
static MotionController * CreateFromSoftware ()
static MotionController * CreateFromSoftware (const char *const RtaPath)
static MotionController * CreateFromSoftware (const char *const RtaPath, const char *const NodeName)
static MotionController * Create ()
static MotionController * CreateFromFile (const char *const fileName)
 Create a MotionController from a memory-dumped file.
Functions
Axis * AxisGet (int32_t axisNumber)
MultiAxis * MultiAxisGet (int32_t motionSupervisorNumber)
MultiAxis * LoadExistingMultiAxis (int32_t motionSupervisorNumber)
 Get/Create a MultiAxis object from one that already exists (previously setup) on the RMP motion controller firmware.
NetworkNode * NetworkNodeGet (int32_t nodeNumber)
 NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializes its internals.
IO * IOGet (int32_t nodeNumber)
void Delete (void)
void Reset ()
 Reset the controller which stops and restarts the RMP firmware.
void Refresh ()
 Refresh / reinitialize the motion controller. Required after changing dynamic memory object counts.
void Shutdown ()
 Shutdown the controller.
void MemoryToFile (const char *const fileName)
 Saves an RMP firmware memory dump which can be compared with others.
int32_t SampleCounterGet ()
 Get the current value of the controller's processor's sample counter.
double ProcessorUsageGet ()
 Get the processor usage percent.
void ProcessorUsageClear ()
 Clear the processor usage percent.
uint32_t FirmwareTimingDeltaGet ()
 Get the most recent time (in microseconds) between samples.
CreationParameters CreationParametersGet ()
 Get the CreationParameters identifying this controller's firmware.
uint32_t SerialNumberGet (void)
void SampleWait (uint32_t samples)
RSIControllerType ControllerTypeGet ()
 Get the type of motion controller.
const char *const ServerNameGet ()
 Get the name of the server. (Valid if controller type is CLIENT.).
int32_t ServerPortGet ()
 Get the TCP port of the server. (Valid if controller type is CLIENT.).
RSIProcessorType ProcessorTypeGet ()
 Get the processor type.
void SampleRateSet (double sampleRate)
 Configure the RMP firmware control loop frequency.
double SampleRateGet ()
int32_t AxisCountGet ()
void AxisCountSet (int32_t axisCount)
void AxisCountSet (int32_t axisCount, bool setMotorFilterSupervisor)
bool IsLicensed ()
 Check to see if this MotionController is licensed.
int32_t PackageVariantGet ()
 Get the motion controller package.
int32_t AxisLicenseCountGet ()
 Get the number of licensed Axis objects on this motion controller. If you need more, call RSI.
bool MechaWareLicenseGet ()
 Returns true if this motion controller is licensed to run MechaWare.
int32_t UnsupportedOptionSet (int32_t option)
 deprecated
int32_t MotionCountGet ()
void MotionCountSet (int32_t motionCount)
int32_t UserVersionGet ()
 Get a customer designated Version for the application.
void UserVersionSet (int32_t version)
 Sets a customer designed Version for the application.
int32_t ExternalMemorySizeGet ()
void AxisFrameBufferSizeSet (int32_t axisNumber, int32_t frameBufferSize)
 Set Frame buffer size for the axis.
int32_t AxisFrameBufferSizeGet (int32_t axisNumber)
 Get Frame buffer size for the axis.
const char *const FirmwareVersionGet ()
 Get the firmware version.
int32_t FirmwareOptionGet ()
 Get the firmware option number.
bool HasMechaWare ()
 Returns true if this RMP firmware supports MechaWare.
int32_t MemoryGet (uint64_t address)
 Read controller memory.
double MemoryDoubleGet (uint64_t address)
 Read a 64-bit double value from controller memory.
void MemoryBlockGet (uint64_t address, void *dataStart, int32_t size)
void MemorySet (uint64_t address, int32_t data)
void MemoryDoubleSet (uint64_t address, double dataDouble)
void MemoryBlockSet (uint64_t address, const void *const dataStart, int32_t size)
 Set controller memory.
uint64_t FirmwareAddressGet (uint64_t hostAddress)
 Convert a host controller address to a firmware address.
uint64_t HostAddressGet (uint64_t firmwareAddress)
 Convert a firmware address to a host controller address.
int32_t BackgroundCycleCounterGet ()
 Get the current value of the controller's processor's background cycle counter.
uint64_t AddressFromStringGet (const char *const addressName)
 Get a controller memory address from string.
const char *const StringFromAddressGet (uint64_t hostAddress)
 Get a human-readable string from a memory address.
uint64_t AddressGet (RSIControllerAddressType type)
uint64_t AddressGet (RSIControllerAddressType type, int32_t objectIndex)
RSIDataType AddressDataTypeGet (RSIControllerAddressType type)
 Get the data type for an address on the MotionController.
RSIDataType AddressDataTypeGet (RSIControllerAddressType type, int32_t objectIndex)
 Get the data type for an address on the MotionController with a specified object index.
bool MotionHoldGateGet (int32_t gateNumber)
void MotionHoldGateSet (int32_t gateNumber, bool hold)
 Set the Motion Hold Gate.
RSINetworkTechnologyType NetworkTechnologyTypeGet ()
 Get the network technology type EtherCAT.
RSINetworkType NetworkTypeGet ()
 Returns network type. (Currently only STRING type is supported.).
int32_t NetworkNodeCountGet ()
 Get the number of nodes discovered on the EtherCAT network.
RSINetworkEniResult NetworkEniGenerate ()
 Generate the network ENI file, EtherCAT.xml.
const char *const NetworkEniGenerateOutputGet ()
 Retrieve the text output from the previous NetworkEniGenerate() call.
void NetworkStart ()
 Start the network, doing both a discovery followed by starting to OPERATIONAL state.
void NetworkStart (RSINetworkStartupMethod startupMethod)
 Start the EtherCAT Network to OPERATIONAL state. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void NetworkStart (RSINetworkStartMode startMode, RSINetworkStartupMethod startupMethod)
 Start the EtherCAT Network to PREOPERATIONL or OPERATIONAL state, with our without discovery. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void NetworkStart (RSINetworkStartMode startMode, RSINetworkStartupMethod startupMethod, uint32_t timeoutMilliseconds)
void NetworkShutdown ()
 Shutdown the EtherCAT network.
RSINetworkState NetworkStateGet ()
NetworkStatus NetworkStatusGet ()
 Get the EtherCAT network status.
int32_t NetworkSyncGroupCountGet ()
 Get the number of sync groups present on the network.
NetworkSyncGroupStatus NetworkSyncGroupStatusGet (int32_t groupId)
 Get the status of a single sync group.
void NetworkSyncGroupRecover (int32_t groupId, uint32_t timeoutMilliseconds=NetworkSyncGroupRecoverTimeoutMillisecondsDefault)
 Recover a degraded (non-zero) sync group back to Operational without restarting the network.
int32_t NetworkCounterGet ()
 Read the network counter. This increments by one for each cycle of the network.
int32_t NetworkInputCountGet ()
int32_t NetworkInputBitSizeGet (int32_t index)
const char *const NetworkInputDataTypeNameGet (int32_t index)
 Get the data type name (as a string) of a PDO network input.
RSIDataType NetworkInputDataTypeGet (int32_t index)
 Get the RSIDataType for a PDO input.
int32_t NetworkInputBitOffsetGet (int32_t index)
const char *const NetworkInputNameGet (int32_t index)
uint64_t NetworkInputValueGet (int32_t index)
FirmwareValue NetworkInputFirmwareValueGet (int32_t index)
 Get the typed value for a PDO input.
uint64_t NetworkInputAddressGet (int32_t index)
 Get the host address for a PDO input.
int32_t NetworkOutputCountGet ()
int32_t NetworkOutputBitSizeGet (int32_t index)
const char *const NetworkOutputDataTypeNameGet (int32_t index)
 Get the data type name (as a string) of a PDO network output.
RSIDataType NetworkOutputDataTypeGet (int32_t index)
 Get the RSIDataType for a PDO output.
int32_t NetworkOutputBitOffsetGet (int32_t index)
 Get the raw PDO offset for an output.
const char *const NetworkOutputNameGet (int32_t index)
 Get the name of a PDO output.
uint64_t NetworkOutputValueGet (int32_t index)
 Gets the value sent out over EtherCAT.
void NetworkOutputValueSet (int32_t index, uint64_t outputValue)
 Sets a PDO output directly.
uint64_t NetworkOutputAddressGet (int32_t index)
 Get the host address for a Network Output.
uint64_t NetworkOutputAddressGet (int32_t index, RSINetworkOutputAddressType type)
uint64_t NetworkOutputIntendedValueGet (int32_t index)
 Gets the value set by the cyclic RMP processes.
FirmwareValue NetworkOutputIntendedFirmwareValueGet (int32_t index)
 Gets the typed value set by the cyclic RMP processes.
void NetworkOutputOverrideSet (int32_t index, bool outputOverride)
bool NetworkOutputOverrideGet (int32_t index)
 Gets if the NetworkOutputValue or the RMP cyclic value is exchanged over EtherCAT.
void NetworkOutputOverrideValueSet (int32_t index, uint64_t outputValue)
void NetworkOutputOverrideFirmwareValueSet (int32_t index, FirmwareValue value)
 Sets a typed PDO override value.
uint64_t NetworkOutputOverrideValueGet (int32_t index)
FirmwareValue NetworkOutputOverrideFirmwareValueGet (int32_t index)
 Gets the typed PDO override value.
uint64_t NetworkOutputSentValueGet (int32_t index)
FirmwareValue NetworkOutputSentFirmwareValueGet (int32_t index)
 Gets the typed value sent out over EtherCAT.
int32_t NetworkLogMessageCountGet ()
RSINetworkStartError LastNetworkStartErrorGet ()
 Get the last (most recent) network start error.
const char *const NetworkLogMessageGet (int32_t messageIndex)
void NetworkTimingEnableSet (bool enable)
 Enable or disable the firmware to start timing the network packets.
bool NetworkTimingEnableGet ()
 Returns true if firmware network packet timing metrics are enabled.
void NetworkTimingClear ()
 Clear all the network timing values.
uint32_t NetworkTimingDeltaGet ()
 Get the number of microseconds since the previous network packet was sent.
uint32_t NetworkTimingMinGet ()
 Get the minimum microseconds recorded between network packets.
uint32_t NetworkTimingMaxGet ()
 Get the maximum microseconds recorded between consecutive network packets.
void NetworkTimingThresholdLowSet (uint32_t microseconds)
 Set a low threshold. The RMP will count the number of network packets sent below this threshold (too short between packets).
void NetworkTimingThresholdHighSet (uint32_t microseconds)
 Set a high threshold. The RMP will count the number of network packets sent above this threshold (too long between packets).
uint32_t NetworkTimingThresholdLowCountGet ()
 Get the number of network packets that were sent to quickly (below the low threshold).
uint32_t NetworkTimingThresholdHighCountGet ()
 Get the number of network packets that were sent to slowly (above the high threshold).
bool NetworkSynchronizedGet ()
 Returns true if the network is synchronized with distributed clocks.
void InterruptWake ()
 Wake all threads waiting for a controller interrupt.
void SyncInterruptEnableSet (bool enable)
void SyncInterruptPeriodSet (uint32_t samples)
int32_t SyncInterruptWait ()
bool ServiceThreadStateGet ()
 Returns true if the service thread was started.
int32_t SyncInterruptHostProcessTimeGet ()
 Get the total number of microseconds availble for host processing.
int32_t SyncInterruptHostProcessFlagGet ()
 Get the host process flag.
void SyncInterruptHostProcessFlagSet (bool hostProcessFlag)
 Set the Host Process flag.
bool SyncInterruptHostProcessStatusBitGet ()
 See if the host was processing too int32_t on previous Sync Interrupt.
void SyncInterruptHostProcessStatusClear ()
 Clear the Host Process status bit.
void ServiceThreadEnableSet (bool enable)
 Enable or disable the service thread.
int32_t RecorderCountGet ()
 Get the number of Recorder available in the firmware.
void RecorderCountSet (int32_t recorderCount)
void RecorderPeriodSet (uint32_t samples)
void RecorderPeriodSet (int32_t recorderNumber, uint32_t samples)
void RecorderCircularBufferSet (bool enable)
void RecorderCircularBufferSet (int32_t recorderNumber, bool enable)
void RecorderDataCountSet (int32_t count)
void RecorderDataCountSet (int32_t recorderNumber, int32_t count)
void RecorderDataAddressSet (int32_t index, uint64_t address)
void RecorderDataAddressSet (int32_t recorderNumber, int32_t index, uint64_t address)
void RecorderDataAddressesSet (int32_t recorderNumber, const uint64_t *const addresses, int32_t addressCount)
 Setup multiple addresses to record at once.
void RecorderConfigureToTriggerOnMotion (Axis *axis, bool triggerOnMotion)
 Configure the Recorder 0 to trigger on Axis motion.
void RecorderConfigureToTriggerOnMotion (int32_t recorderNumber, Axis *axis, bool triggerOnMotion)
 Configure the recorder to trigger on Axis motion.
void RecorderConfigureToTriggerOnMotion (MultiAxis *multiAxis, bool triggerOnMotion)
 Configure Recorder 0 to trigger on MultiAxis motion.
void RecorderConfigureToTriggerOnMotion (int32_t recorderNumber, MultiAxis *multiAxis, bool triggerOnMotion)
 Configure the recorder to trigger on MultiAxis motion.
void RecorderConfigureToTriggerOnMotion (int32_t recorderNumber, int32_t motionNumber, bool triggerOnMotion)
 Configure the recorder to trigger on motion with a specific motion number.
bool RecorderTriggerOnMotionGet (int32_t recorderNumber)
 Check to see if the Recorder is set to trigger on motion.
bool RecorderEnabledGet ()
bool RecorderEnabledGet (int32_t recorderNumber)
int32_t RecorderRecordCountGet ()
int32_t RecorderRecordCountGet (int32_t recorderNumber)
int32_t RecorderRecordMaxCountGet ()
 Get the maximum number of records the recorder can store on Recorder 0.
int32_t RecorderRecordMaxCountGet (int32_t recorderNumber)
void RecorderStart ()
 Start recording data.
void RecorderStart (int32_t recorderNumber)
void RecorderStop ()
void RecorderStop (int32_t recorderNumber)
const int32_t *const RecorderRecordDataGet ()
 Get one record of recorded data on Recorder 0.
const int32_t *const RecorderRecordDataGet (int32_t recorderNumber)
void RecorderRecordDataRetrieve ()
int32_t RecorderRecordDataRetrieveBulk (int32_t recorderNumber, int32_t recordCount)
 Retrieve a group of records of recorded data.
void RecorderRecordDataRetrieve (int32_t recorderNumber)
int32_t RecorderRecordDataValueGet (int32_t index)
int32_t RecorderRecordDataValueGet (int32_t recorderNumber, int32_t index)
int32_t RecorderRecordDataValueGet (int32_t recorderNumber, int32_t recordIndex, int32_t dataIndex)
 Get one indexed data value from collected data.
double RecorderRecordDataDoubleGet (int32_t index)
double RecorderRecordDataDoubleGet (int32_t recorderNumber, int32_t index)
double RecorderRecordDataDoubleGet (int32_t recorderNumber, int32_t recordIndex, int32_t dataIndex)
 Get one indexed double value from collected data.
FirmwareValue RecorderRecordDataFirmwareValueGet (int32_t index)
FirmwareValue RecorderRecordDataFirmwareValueGet (int32_t recorderNumber, int32_t index)
FirmwareValue RecorderRecordDataFirmwareValueGet (int32_t recorderNumber, int32_t recordIndex, int32_t dataIndex)
 Get one indexed FirmwareValue from collected data.
void RecorderBufferHighCountSet (int32_t bufferHighCount)
 Set the high count for the recording buffer on Recorder 0.
void RecorderBufferHighCountSet (int32_t recorderNumber, int32_t bufferHighCount)
void RecorderReset ()
void RecorderReset (int32_t recorderNumber)
int32_t RecorderBufferSizeGet (int32_t recorderNumber)
 Get Frame buffer size for the Recorder.
void RecorderBufferSizeSet (int32_t recorderNumber, int32_t bufferSize)
 Set buffer size for the Recorder.
int32_t CompensatorCountGet ()
 Get the number of Compensators available in the firmware.
void CompensatorCountSet (int32_t compensatorCount)
 Set the number of Compensators available in the firmware.
int32_t CompensatorPointCountGet (int32_t compensatorNumber)
 Get the number of points for use with a Compensator.
void CompensatorPointCountSet (int32_t compensatorNumber, int32_t pointCount)
 Set the number of points for use with a Compensator.
int32_t CompensatorDimensionGet (int32_t compensatorNumber)
 Get the dimension of the compensator.
void CompensatorConfigSet (int32_t compensatorNumber, int32_t firstInputAxisNumber, RSIAxisMasterType firstInputAxisType, double firstInputAxisMinimum, double firstInputAxisMaximum, double firstInputAxisDelta, int32_t secondInputAxisNumber, RSIAxisMasterType secondInputAxisType, double secondInputAxisMinimum, double secondInputAxisMaximum, double secondInputAxisDelta, int32_t outputAxisNumber, RSICompensatorOutputType outputType, const double *const table)
 Configure a 2D compensator.
void CompensatorConfigSet (int32_t compensatorNumber, Axis *firstInputAxis, RSIAxisMasterType firstInputAxisType, double firstInputAxisMinimum, double firstInputAxisMaximum, double firstInputAxisDelta, Axis *secondInputAxis, RSIAxisMasterType secondInputAxisType, double secondInputAxisMinimum, double secondInputAxisMaximum, double secondInputAxisDelta, Axis *outputAxis, RSICompensatorOutputType outputType, const double *const table)
 Configure a 2D compensator. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void CompensatorConfigSet (int32_t compensatorNumber, int32_t inputAxisNumber, RSIAxisMasterType inputAxisType, double inputAxisMinimum, double inputAxisMaximum, double inputAxisDelta, int32_t outputAxisNumber, RSICompensatorOutputType outputType, const double *const table)
 Configure a 1D compensator.
void CompensatorConfigSet (int32_t compensatorNumber, Axis *inputAxis, RSIAxisMasterType inputAxisType, double inputAxisMinimum, double inputAxisMaximum, double inputAxisDelta, Axis *outputAxis, RSICompensatorOutputType outputType, const double *const table)
void CompensatorTableSet (int32_t compensatorNumber, const double *const table)
 Override the table for a configured compensator.
void CompensatorTableGet (int32_t compensatorNumber, double *table)
 Read the table for a configured compensator.
double CompensatorPositionGet (int32_t compensatorNumber)
 Get the compensator position.
void CompensatorTableClear (int32_t compensatorNumber)
 Sets all values in the compensator table to 0.
void CompensatorDisable (int32_t compensatorNumber, bool force=false)
 Disable a compensator with the option to force the action.
void CompensatorEnable (int32_t compensatorNumber)
 Enables the compensator only if it will cause no errors.
int32_t UserLimitCountGet ()
 Get the number of UserLimits processing in the firmware.
void UserLimitCountSet (int32_t userLimitCount)
void UserLimitConfigSet (int32_t number, RSIUserLimitTriggerType triggerType, RSIAction action, int32_t actionAxis, double duration, bool singleShot)
 Configure a User Limit.
void UserLimitConfigSet (int32_t number, RSIUserLimitTriggerType triggerType, RSIAction action, int32_t actionAxis, double duration)
RSIUserLimitTriggerType UserLimitTriggerTypeGet (int32_t number)
 Get the user limit trigger type.
RSIAction UserLimitActionGet (int32_t number)
 Get the user limit action.
int32_t UserLimitAxisNumberGet (int32_t number)
 Get the user limit axis number.
double UserLimitDurationGet (int32_t number)
 Get the user limit duration (seconds).
bool UserLimitSingleShotGet (int32_t number)
 Returns true if the user limit is configured for single-shot.
void UserLimitConditionSet (int32_t number, int32_t conditionNumber, RSIUserLimitLogic logic, uint64_t addressOfUInt32, uint32_t userLimitMask, uint32_t limitValueUInt32)
void UserLimitConditionSet (int32_t number, int32_t conditionNumber, RSIUserLimitLogic logic, uint64_t addressOfDouble, double limitValueDouble)
 Set the conditions for a User Limit with a 64-bit double precision trigger value.
RSIDataType UserLimitConditionDataTypeGet (int32_t number, int32_t conditionNumber)
 Get the user limit condition data type.
RSIUserLimitLogic UserLimitConditionLogicGet (int32_t number, int32_t conditionNumber)
 Get the user limit condition logic.
uint64_t UserLimitConditionAddressGet (int32_t number, int32_t conditionNumber)
 Get the user limit condition address.
uint32_t UserLimitConditionMaskGet (int32_t number, int32_t conditionNumber)
 Get the user limit condition mask.
int32_t UserLimitConditionLimitValueGet (int32_t number, int32_t conditionNumber)
 Get the user limit condition value.
double UserLimitConditionLimitValueDoubleGet (int32_t number, int32_t conditionNumber)
 Get the user limit condition limit value (as 64-bit double).
void UserLimitOutputSet (int32_t number, uint32_t andMask, uint32_t orMask, uint64_t outputPtr, bool enabled)
 Configure a User Limit Output block.
void UserLimitOutputSet (int32_t number, int32_t valueSet, uint64_t outputPtr, bool enabled)
 User Limit will output a 32-bit value. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void UserLimitOutputSet (int32_t number, uint64_t andMask, uint64_t orMask, uint64_t outputPtr, bool enabled)
 User Limit will output a 64-bit value with an AND and OR masks. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void UserLimitOutputSet (int32_t number, double limitValueDouble, uint64_t outputPtr, bool enabled)
void UserLimitOutputSet (int32_t number, RSIDataType dataType, uint64_t inputPtr, uint64_t outputPtr, bool enabled)
 Configure a User Limit Output block to copy a value, then output the value.
bool UserLimitOutputEnableGet (int32_t number)
 Returns true if the user limit output is enabled.
RSIDataType UserLimitOutputDataTypeGet (int32_t number)
 Get the user limit output data type.
uint64_t UserLimitOutputAddressGet (int32_t number)
 Get the user limit output address. The output will write its value to this address.
uint64_t UserLimitOutputInputAddressGet (int32_t number)
 Get the user limit output address. The user limit will output the value stored at this address when the user limit triggers.
uint32_t UserLimitOutputAndMaskGet (int32_t number)
 Get the user limit output AND mask.
uint32_t UserLimitOutputOrMaskGet (int32_t number)
 Get the user limit output OR mask.
int32_t UserLimitOutputValueGet (int32_t number)
 Get the user limit output value.
uint64_t UserLimitOutputAndMask64Get (int32_t number)
 Get the user limit output 64-bit AND mask.
uint64_t UserLimitOutputOrMask64Get (int32_t number)
 Get the user limit output 64-bit OR mask.
double UserLimitOutputDoubleGet (int32_t number)
 Get the user limit output 64-bit double value.
bool UserLimitStateGet (int32_t number)
 Get the state of a User Limit.
bool UserLimitEnableGet (int32_t number)
 Get the enabled state of a User Limit.
void UserLimitEnableSet (int32_t number, bool enable)
 Enable or disable a user limit to be processed by the RMP firmware.
void UserLimitDisable (int32_t number)
void UserLimitReset (int32_t number)
 Clear the latched status of a User Limit.
int32_t UserLimitCountMax ()
 Get the total number of User Limits available.
void UserLimitInterruptUserDataAddressSet (int32_t number, uint32_t userDataIndex, uint64_t address)
uint64_t UserLimitInterruptUserDataAddressGet (int32_t number, uint32_t userDataIndex)
 Get the user limit interrupt user data address.
int32_t MathBlockCountGet ()
void MathBlockCountSet (int32_t mathBlockCount)
MathBlockConfig MathBlockConfigGet (int32_t mathBlockNumber)
void MathBlockConfigSet (int32_t mathBlockNumber, MathBlockConfig &config)
FirmwareValue MathBlockProcessValueGet (int32_t mathBlockNumber)
void InterruptMaskClear ()
void InterruptMaskAllSet ()
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t NumberGet ()
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Attributes
RapidCodeOS * OS
Static Attributes
static constexpr uint32_t NetworkStartTimeoutMillisecondsDefault = 30000
 Default time to wait when calling NetworkStart().
static constexpr uint32_t NetworkSyncGroupRecoverTimeoutMillisecondsDefault = 5000
 Default per-node AL-transition time to wait when calling NetworkSyncGroupRecover().
static constexpr uint32_t AxisCountMaximum = 128
 Maximum number of Axis objects supported.
static constexpr uint32_t MotionControllerCountMaximum = 2
 Maximum number of MotionController objects supported in a single process.
static constexpr uint32_t MotionCountMaximum = 128
 Maximum number of Motion objects supported. (One required for each Axis and MultiAxis).
static constexpr uint32_t NetworkNodeCountMaximum = 128
 Maximum number of nodes allowed on the network.
static constexpr uint32_t NetworkSyncGroupCountMaximum = 8
 Maximum number of EtherCAT sync groups supported, including the mandatory default group 0. Valid group ids are [0, NetworkSyncGroupCountMaximum). See Sync Groups.
static constexpr uint32_t RecorderCountMaximum = 128
 Maximum number of Recorder objects supported.
static constexpr uint32_t CompensatorCountMaximum = 128
 Maximum number of position Compensator objects supported.
static constexpr uint32_t MathBlockCountMaximum = 128
 Maximum number of MathBlock objects supported.
static constexpr uint32_t UserBufferDataCountMaximum = 1024
 Maximum number of 64-bit values that can be stored in the UserBuffer.
static constexpr double SampleRateDefault = 1000.0
 Default RMP sample rate in hertz.
static constexpr int32_t AxisFrameBufferSizeDefault = 1024
Classes
struct  CreationParameters
 CreationParameters for MotionController::Create. More...
struct  MathBlockConfig
 MathBlock configuration structure. More...
struct  NetworkStatus
 NetworkStatus structure for EtherCAT network health monitoring. More...
struct  NetworkSyncGroupStatus
 Status of a single EtherCAT sync group. More...
Description
ControllerInterrupts.cpp, Gantry.cpp, HardwareLimits.cpp, Memory.cpp, MotionHoldReleasedBySoftwareAddress.cpp, MultiaxisMotion.cpp, PVTmotionMultiAxis.cpp, PathMotion.cpp, SingleAxisSyncOutputs.cpp, StreamingMotionBufferManagement.cpp, SyncInterrupt.cpp, SyncOutputWithMotion.cpp, UpdateBufferPoints.cpp, UserLimitDigitalInputAction.cpp, _helpers.cs, _setup.cs, axis-config-ampfault.cs, axis-config-hardware-limits.cs, axis-config-phantom-axis.cs, axis-config-settling.cs, axis-config-stop-rate.cs, axis-config-userunits.cs, axis-configuration.cpp, axis-homing-akd-drive.cs, axis-homing-ds402-drive.cs, axis-homing-master-based.cs, axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, axis-motion-hold-via-position.cs, axis-motion-modify.cs, axis-motion-point-to-point.cs, axis-motion-streaming-pt-whilestopping.cs, axis-motion-streaming-pt.cs, axis-motion-streaming-pvajt.cs, axis-motion-streaming-pvt.cs, axis-motion-velocity-via-analoginput.cs, axis-status.cs, basic-template.cs, calculate-acceleration-from-velocity.cpp, camming.cs, compensator-1d.cs, compensator-2d.cs, compensator-single-axis.cs, config.h, difference-of-position-user-limit.cpp, error-logs.cs, follow-sensor.cpp, gcode-motion.cs, gcode-units.cs, gearing.cs, hello-rttasks.cpp, helpers.h, io-dedicated.cs, io-general-purpose.cs, io-iopoint-user-buffer.cs, io-iopoint.cs, io-network-pdo-sdo.cs, io-sync-outputs.cs, mathblock-calculate-acceleration-from-velocity.cs, mathblock-difference-of-position-userlimit.cs, mathblock-pdo-copy.cs, multiaxis-motion-point-to-point.cs, multiaxis-motion-velocity.cs, path-3d-points.cs, path-motion.cs, path-setup-gantry.cs, phantom-axis.cpp, point-to-point.cpp, print-network-topology.cpp, record-performance.cpp, recorder.cs, rttaskfunctions.cpp, rttaskglobals.h, starter-template.cpp, touch-probe.cs, userlimit-command-position-direct.cs, userlimit-digital-input-one-condition.cs, userlimit-digital-input-two-condition.cs, userlimit-estop-store-position.cs, userlimit-feedrate.cs, and userlimit-position-abort.cs.
Definition at line 796 of file rsi.h.
