◆ SyncInterruptPeriodSet()
void SyncInterruptPeriodSet ( uint32_t samples)
SyncInterruptPeriodSet configures the number of Controller firmware foreground samples between Sync interrupts. Therefore, an interrupt will be generated every [x] samples.
samplesThe number of foreground cycles between successive interrupts from the controller.
Configure for a Sync interrupt every 10ms (assumes controller running at default 2000Hz sample rate)
// -- C++ -- //
controller->SyncInterruptPeriodSet(20);
// -- C# -- //
controller.SyncInterruptPeriodSet(20);
The Sync Interrupt is only intended for real-time operating systems.
InterruptWait
StreamingMotionBufferManagement.cpp.
