◆ RecorderCircularBufferSet()
void RecorderCircularBufferSet ( bool enable)
RecorderCircularBufferSet configures recorder as circular buffer on or off.
enableTrue = recorder keeps recording (and overwriting) after buffer is full, False = stops recording when buffer is full.
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12981
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
RecorderStop
