◆ MoveVelocitySCurve()
void MoveVelocitySCurve ( double velocity,
double accel,
double jerkPct )
MoveVelocitySCurve commands a constant velocity move (jog) with non-constant acceleration.
velocityTarget velocity, UserUnits/second.
accelAverage acceleration, UserUnits/second/second. (peak up to 2× accel when jerkPercent = 100, see below)
jerkPctWhich defines the percentage of acceleration time which is smoothed, 0.0 to 100.0.
Using a non-zero JerkPercent increases the maximum acceleration above the user-specified average.
If your system can’t handle the higher peak, you risk overshoot or excessive load. The relation between average acceleration and maximum acceleration is:
axis->MoveVelocitySCurve(1000.0, 10000.0, 50.0);
Motion Scope:
Velocity move (SCurve type) profile shown below:
Velocity Motion,, MoveSCurve, MoveTrapezoidal, MovePT, MovePVT
