MotionController::NetworkStatus
NetworkStatus structure for EtherCAT network health monitoring. More...
Attributes
uint32_t ActiveNodeCount
 Number of nodes actively responding on the network. Compare against expected node count to detect dropped nodes.
uint32_t AlStatus
 Logical OR of AL Status registers (0x0130) from all nodes. A value of 8 indicates all nodes are Operational with no errors. This is a snapshot value primarily useful for detecting unexpected node state transitions (e.g., a node falling out of OP). May not reflect current state after network shutdown. Bits 0-3 indicate Device State Machine state: 1=Init, 2=PreOp, 3=Bootstrap, 4=SafeOp, 8=Operational. Bit 4 is the Error Flag.
uint32_t CyclicFramePeriodUs
 Most recent cyclic frame period in microseconds. Should match the configured sample rate.
uint64_t EoeHostToNodeFrameCount
 Cumulative count of EoE (Ethernet over EtherCAT) frames sent from the host toward nodes since network start, across the whole network. Counts every host-originated EoE frame, including broadcasts that target all nodes, so this is greater than or equal to the sum of the per-node NetworkNode::Status::EoeHostToNodeFrameCount. Use to confirm EoE traffic is flowing out to the drives. See EoE - Ethernet over EtherCAT.
uint64_t EoeNodeToHostFrameCount
 Cumulative count of EoE (Ethernet over EtherCAT) frames received from nodes by the host since network start, across the whole network. Use to confirm EoE responses are returning from the drives. See EoE - Ethernet over EtherCAT.
RSINetworkInterfaceType InterfaceType
 Host-side packet interface mechanism used for EtherCAT frame I/O (for example, INtime HPE2 or Linux AF_PACKET/AF_XDP).
uint32_t MissedCyclicFrameCount
 Cumulative count of missed cyclic EtherCAT frames since network startup. Indicates communication reliability issues.
int32_t SynchronizationErrorNs
 Distributed Clock synchronization error in nanoseconds. Updated approximately every 16 samples. Non-zero values indicate DC sync drift.
Description
NetworkStatus structure for EtherCAT network health monitoring. Use this structure to monitor EtherCAT network health, detect communication failures, and diagnose timing issues. The values are updated cyclically by the EtherCAT master. Every dynamic field is also recordable via AddressGet with the matching RSIControllerAddressTypeNETWORK_STATUS_* entry (per-node values use ::RSINetworkNodeAddressType with RapidCodeNetworkNode::AddressGet).
NetworkStatusGet, NetworkNode::Status
Definition at line 2280 of file rsi.h.
