11.1.1
OperationModeSet()
void OperationModeSet
RSIOperationMode
mode
OperationModeSet will set the axis operation mode. This is associated with the CiA DS402 0x6060 object (Modes of Operation). For multi-axis drives, the SDO index is automatically adjusted based on
DriveIndexGet()
Drive index 0: 0x6060
Drive index 1: 0x6860 (0x6060 + 0x800)
Drive index 2: 0x7060 (0x6060 + 0x1000), etc.
mode
Operation Mode.
We recommend that you avoid using this function while the axis is enabled. This function uses PDO (cyclic) communication when the
NetworkIndexGet()
with
RSINetworkIndexType::NetworkIndexTypeMODE_OF_OPERATION_INDEX
is valid. Otherwise, it falls back to SDO (acyclic) communication via
ServiceChannelWrite
, using the axis-specific SDO index.
OperationModeGet
DriveIndexGet
NetworkIndexGet
axis-homing-akd-drive.cs
, and
axis-homing-ds402-drive.cs
1.15.0
