◆ InterruptSourceNumberGet()
int32_t InterruptSourceNumberGet ( )
inherited
InterruptSourceNumberGet returns the number of the object (Axis, Motor, etc) that generated the interrupt.
(int32_t) Index or number of the object that generated the interrupt.
IO: User Limits
Console.WriteLine("šŸ“œ User Limit: Command Position Direct Set");
const int DURATION = 0;
// configure user limits
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ FIRST USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_FIRST,
conditionNumber: 0,
actionAxis: axis.NumberGet(),
duration: DURATION,
singleShot: ONE_SHOT);
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ SECOND USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_SECOND,
conditionNumber: 0,
userLimitMask: 1,
limitValueUInt32: 1);
conditionNumber: 1,
limitValueDouble: 0.0);
actionAxis: 0,
duration: 0,
// start motion
axis.ClearFaults();
axis.Abort();
axis.ClearFaults();
Console.WriteLine($"āŒ Error: {e.Message}");
number: userLimitIndex,
bool done = false;
int interruptCount = 0;
while (!done)
interruptCount++;
switch (eventType)
done = true;
Console.WriteLine($"\nāœ“ Completed - received {interruptCount} interrupts");
default:
NetworkNode * NetworkNode
Definition rsi.h:7077
int32_t NumberGet()
Get the axis number.
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Definition rsienums.h:451
Trigger types for UserLimits.
Definition rsienums.h:758
For UserLimit objects, RapidCode internally uses one UserLimit per Axis. To determine which UserLimit triggered, you must subtract the AxisCount.
int32_t triggeredUserLimit = controller.InterruptSourceNumberGet()-AXIS_COUNT;
