◆ MotionHoldUserPatternSet()
void MotionHoldUserPatternSet ( int32_t pattern)
MotionHoldUserPatternSet sets the pattern bitmask which will be compared for equality after the Mask has been evaluated.
patternThe bitmask
Motion: Hold
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Definition rsi.h:6515
Set the motion hold type.
Definition rsienums.h:617
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
MotionHoldUserAddressSet(), MotionHoldTypeSet()
MotionHoldReleasedBySoftwareAddress.cpp, axis-motion-hold-via-address.cs, and axis-motion-hold-via-digitalinput.cs.
