◆ SoftwarePosLimitActionSet()
void SoftwarePosLimitActionSet ( RSIAction action)
SoftwarePosLimitActionSet sets the action that will occur when the Software Positive Limit Event triggers.
actionAction taken on Limit trigger. A ::RSIAction value.
Note:
Axis: Configuration
// add phantom axis
// get phantom axis
Go to axis screen->Limits & Actions. In image below, SoftwarePosLimitActionSet sets the action type shown in the Positive (+) Software box. It is currently set to E_STOP.
SoftwarePosLimitActionGet
PathMotion.cpp, _helpers.cs, axis-config-phantom-axis.cs, config.h, and phantom-axis.cpp.
