strong |
| Enumerator | |
| RSIAxisMessageAXIS_INVALID |
| RSIAxisMessageCOMMAND_NOT_SET |
| RSIAxisMessageNOT_MAPPED_TO_MS |
| RSICaptureMessageMOTOR_INVALID |
| RSICaptureMessageCAPTURE_TYPE_INVALID |
| RSICaptureMessageCAPTURE_INVALID |
| RSICaptureMessageFEEDBACK_INVALID |
| RSICaptureMessageINVALID_EDGE |
| RSICaptureMessageCAPTURE_NOT_ENABLED |
| RSICaptureMessageCAPTURE_STATE_INVALID |
| RSICaptureMessageUNSUPPORTED_PRIMARY |
| RSICaptureMessageUNSUPPORTED_SECONDARY |
| RSICaptureMessageCAPTURE_ARMED |
| RSICommandMessageTYPE_INVALID |
| RSICompensatorMessageCOMPENSATOR_INVALID |
| RSICompensatorMessageNOT_CONFIGURED |
| RSICompensatorMessageNOT_ENABLED |
| RSICompensatorMessageAXIS_NOT_ENABLED |
| RSICompensatorMessageTABLE_SIZE_ERROR |
| RSICompensatorMessagePOSITION_DELTA_INVALID |
| RSICompensatorMessageDIMENSION_NOT_SUPPORTED |
| RSIControlMessageLIBRARY_VERSION |
| RSIControlMessageCONTROL_INVALID |
| RSIControlMessageCONTROL_NUMBER_INVALID |
| RSIControlMessageTYPE_INVALID |
| RSIControlMessageINTERRUPTS_DISABLED |
| RSIControlMessageINTERNAL_MEMORY_OVERFLOW |
| RSIControlMessageEXTERNAL_MEMORY_OVERFLOW |
| RSIControlMessageBACKGROUND_STARVATION |
| RSIControlMessageMOTOR_COUNT_INVALID |
| RSIControlMessageFILTER_COUNT_INVALID |
| RSIControlMessageAXIS_COUNT_INVALID |
| RSIControlMessageAXIS_FRAME_COUNT_INVALID |
| RSIControlMessageMOTION_COUNT_INVALID |
| RSIControlMessageMATH_BLOCK_COUNT_INVALID |
| RSIControlMessageSEQUENCE_COUNT_INVALID |
| RSIControlMessagePRE_FILTER_DELAY_COUNT_INVALID |
| RSIControlMessageRECORDER_COUNT_INVALID |
| RSIControlMessageLIMIT_BLOCK_COUNT_INVALID |
| RSIControlMessageCOMPENSATOR_COUNT_INVALID |
| RSIControlMessageCAPTURE_COUNT_INVALID |
| RSIControlMessageTX_TIME_INVALID |
| RSIControlMessageSAMPLE_RATE_TO_LOW |
| RSIControlMessageSAMPLE_RATE_TO_HIGH |
| RSIControlMessageAXIS_RUNNING |
| RSIControlMessageRECORDER_RUNNING |
| RSIControlMessagePACK_ALIGNMENT |
| RSIControlMessageFIRMWARE_INVALID |
| RSIControlMessageFIRMWARE_VERSION_NONE |
| RSIControlMessageFIRMWARE_VERSION |
| RSIControlMessageNO_FPGA_SOCKET |
| RSIControlMessageSYNQNET_STATE |
| RSIControlMessageIO_BIT_INVALID |
| RSIControlMessageOBJECT_INDEX_INVALID |
| RSIControlMessageOBJECT_INVALID |
| RSIControlMessageFLASH_SYNQNET_STATE_INVALID |
| RSIControlMessageFLASH_INVALID |
| RSIControlMessageFLASH_VERIFY_ERROR |
| RSIControlMessageFLASH_WRITE_ERROR |
| RSIControlMessageFILE_INACCESSIBLE |
| RSIControlMessageBUFFER_TOO_SMALL |
| RSIControlMessageEVENTS_LOST |
| RSIElementMessageELEMENT_INVALID |
| RSIEventMessageEVENT_INVALID |
| RSIFilterMessageFILTER_INVALID |
| RSIFilterMessageINVALID_ALGORITHM |
| RSIFilterMessageINVALID_DRATE |
| RSIFilterMessageCONVERSION_DIV_BY_0 |
| RSIFilterMessageSECTION_NOT_ENABLED |
| RSIFilterMessageINVALID_FILTER_FORM |
| RSIFilterMessageINVALID_SMOOTHING |
| RSIGeometricPathMessageILLEGAL_DIMENSION |
| RSIGeometricPathMessageILLEGAL_ELEMENT |
| RSIGeometricPathMessageARC_ILLEGAL_DIMENSION |
| RSIGeometricPathMessageILLEGAL_RADIUS |
| RSIGeometricPathMessagePATH_TOO_LONG |
| RSIGeometricPathMessageUNSUPPORTED_TYPE |
| RSIGeometricPathMessageILLEGAL_VELOCITY |
| RSIGeometricPathMessageILLEGAL_ACCELERATION |
| RSIGeometricPathMessageILLEGAL_TIMESLICE |
| RSILicenseMessageNOT_VALID |
| RSILicenseMessageNOFEATURE |
| RSILicenseMessageNOAXIS |
| RSILicenseMessageCONTROL_TYPE_FILE |
| RSILicenseMessageEXPIRED |
| RSILicenseMessageUNLICENSED |
| RSILicenseMessageNO_APP_LICENSE |
| RSIListMessageELEMENT_NOT_FOUND |
| RSIListMessageELEMENT_INVALID |
| RSIMessageOK |
| RSIMessageARG_INVALID |
| RSIMessagePARAM_INVALID |
| RSIMessageHANDLE_INVALID |
| RSIMessageNO_MEMORY |
| RSIMessageOBJECT_FREED |
| RSIMessageOBJECT_NOT_ENABLED |
| RSIMessageOBJECT_NOT_FOUND |
| RSIMessageOBJECT_ON_LIST |
| RSIMessageOBJECT_IN_USE |
| RSIMessageTIMEOUT |
| RSIMessageUNSUPPORTED |
| RSIMessageFATAL_ERROR |
| RSIMessageFILE_CLOSE_ERROR |
| RSIMessageFILE_OPEN_ERROR |
| RSIMessageFILE_READ_ERROR |
| RSIMessageFILE_WRITE_ERROR |
| RSIMessageFILE_MISMATCH |
| RSIMessageASSERT_FAILURE |
| RSIClientMessageMETHOD_INVALID |
| RSIClientMessageHEADER_INVALID |
| RSIClientMessageRSICONSTANT_INCOMPATIBLE |
| RSIClientMessageSERVER_INCOMPATIBLE |
| RSIClientMessageSERVER_INACCESSIBLE |
| RSIClientMessageCOUNT |
| RSIMotionMessageMOTION_INVALID |
| RSIMotionMessageAXIS_COUNT |
| RSIMotionMessageAXIS_FRAME_COUNT |
| RSIMotionMessageTYPE_INVALID |
| RSIMotionMessageATTRIBUTE_INVALID |
| RSIMotionMessageIDLE |
| RSIMotionMessageMOVING |
| RSIMotionMessageSTOPPING |
| RSIMotionMessageSTOPPED |
| RSIMotionMessageSTOPPING_ERROR |
| RSIMotionMessageERROR |
| RSIMotionMessageAUTO_START |
| RSIMotionMessageILLEGAL_DELAY |
| RSIMotionMessagePROFILE_ERROR |
| RSIMotionMessagePROFILE_NOT_SUPPORTED |
| RSIMotionMessagePATH_ERROR |
| RSIMotionMessageFRAMES_LOW |
| RSIMotionMessageFRAMES_EMPTY |
| RSIMotionMessageFRAME_BUFFER_OVERRUN |
| RSIMotionMessageRESERVED0 |
| RSIMotionMessageRESERVED1 |
| RSIMotionMessageRESERVED2 |
| RSIMotionMessageNO_AXES_MAPPED |
| RSIMotionMessageBAD_PATH_DATA |
| RSIMotionMessageAXIS_MOVING |
| RSIMotionMessageAXIS_MAP_MISMATCH |
| RSIMotorMessageMOTOR_INVALID |
| RSIMotorMessageTYPE_INVALID |
| RSIMotorMessageSTEPPER_NA |
| RSIMotorMessageMOTOR_NOT_ENABLED |
| RSIMotorMessageSECONDARY_FEEDBACK_NA |
| RSIMotorMessageHARDWARE_NOT_FOUND |
| RSIMotorMessageSTEPPER_INVALID |
| RSIMotorMessageDISABLE_ACTION_INVALID |
| RSIMotorMessagePULSE_WIDTH_INVALID |
| RSIMotorMessageFEEDBACK_REVERSAL_NA |
| RSIMotorMessagePHASE_FINDING_FAILED |
| RSIMotorMessageDEMAND_MODE_UNSUPPORTED |
| RSIMotorMessageDEMAND_MODE_NOT_SET |
| RSIMotorMessagePOSITION_FEEDBACK_OFFSET_UNSUPPORTED |
| RSIMotorMessagePOSITION_FEEDBACK_OFFSET_SET_FAILED |
| RSIMotorMessagePOSITION_FEEDBACK_OFFSET_UNINITIALIZED |
| RSIMapMessageNAME_INVALID |
| RSIMapMessageNAME_NOT_FOUND |
| RSIMapMessageINDEX_INVALID |
| RSIMapMessageFILE_INVALID |
| RSIMapMessageSYMBOL_NOT_FOUND |
| RSIMapMessageSYMBOL_INVALID |
| RSIThreadMessageTHREAD_NOT_RUNNING |
| RSIThreadMessageTHREAD_RUNNING |
| RSIThreadMessageTHREAD_NOT_STARTED |
| RSINotifyMessageWAIT_IN_PROGRESS |
| RSIPacketMessageADDRESS_INVALID |
| RSIPacketMessageCOMM_ERROR |
| RSIPacketMessageCONNECTION_CLOSED |
| RSIPlatformMessagePLATFORM_INVALID |
| RSIPlatformMessageDEVICE_INVALID |
| RSIPlatformMessageDEVICE_ERROR |
| RSIPlatformMessageDEVICE_MAP_ERROR |
| RSIPlatformMessageCOPY64_FAILURE |
| RSIPlatformMessagePATH_DOES_NOT_EXIST |
| RSIPlatformMessagePATH_IS_NOT_A_DIRECTORY |
| RSIPlatformMessageINSTALL_VARIABLE_NOT_SET |
| RSIPlatformMessageDRIVER_VERSION_INCOMPATIBLE |
| RSIPlatformMessageFILE_TYPE_INVALID |
| RSIPlatformMessageFILE_VERSION |
| RSIPlatformMessageUSER_IS_NOT_ADMIN |
| RSIPlatformMessageINTIME_VERSION_UNSUPPORTED |
| RSIPlatformMessageINTIME_NODE_DOES_NOT_EXIST |
| RSIPlatformMessageINTIME_NOT_STARTED |
| RSIPlatformMessageRMP_NOT_STARTED |
| RSIPlatformMessageRSI_LICENSE_NOT_FOUND |
| RSIPlatformMessageRSI_LICENSE_INVALID |
| RSIPlatformMessageRSI_USB_SERIAL_NOT_FOUND |
| RSIRecorderMessageSTARTED |
| RSIRecorderMessageSTOPPED |
| RSIRecorderMessageNOT_CONFIGURED |
| RSIRecorderMessageNO_RECORDERS_AVAIL |
| RSIRecorderMessageNOT_ENABLED |
| RSIRecorderMessageRUNNING |
| RSIRecorderMessageRECORD_COUNT_INVALID |
| RSIRecorderMessageRESERVED |
| RSIRecorderMessageNOT_RESERVED |
| RSIServerMessageMETHOD_INVALID |
| RSIServerMessageHEADER_INVALID |
| RSIUserLimitMessageUSER_LIMIT_INVALID |
| RSI_CONTROLLER_INVALID_CONTROLLER_NUMBER | Invalid controller number. |
| RSI_CONTROLLER_INVALID_SERVER_NAME | Invalid server name for CLIENT controller. |
| RSI_CONTROLLER_INVALID_CONTROLLER_TYPE | Invalid controller type. |
| RSI_INVALID_ID | Invalid RSI ID. |
| RSI_CONTROLLER_NOT_SYNC_INTERRUPT | Not the controller Sync interrupt. |
| RSI_CONTROLLER_CUSTOM_FIRMWARE_REQUIRED | Custom controller firmware required. |
| RSI_AXIS_HOME_METHOD_NOT_SUPPORTED | Home Method not (yet) supported. |
| RSI_AXIS_HOME_CAPTURE_FAILED | Capture failed. |
| RSI_AXIS_HOME_CAPTURE_ARMING_FAILED | Capture failed to arm for homing. |
| RSI_AXIS_HOME_INVALID_HOME_VELOCITY | Invalid Home Velocity. |
| RSI_AXIS_HOME_INVALID_HOME_SLOW_VELOCITY | Invalid Home Slow Velocity. |
| RSI_AXIS_HOME_INVALID_HOME_ACCELERATION | Invalid Home Acceleration. |
| RSI_AXIS_HOME_INVALID_HOME_DECELERATION | Invalid Home Deceleration. |
| RSI_AXIS_HOME_CANCELED | User canceled homing operation. |
| RSI_AXIS_HOME_FAILED_TO_REACH_DESIRED_STATE_OF_SWITCH | Homing failed to reach the desired state of a switch. |
| RSI_FUNCTION_NOT_SUPPORTED | This method is not currently supported. |
| RSI_ERROR_LOG_EMPTY | The error log is empty. |
| RSI_ERROR_LOG_FULL | The error log is full. |
| RSI_SQNODE_NOT_IO_NODE | This node is not an I/O node. |
| RSI_AXIS_ADDRESS_TYPE_UNKNOWN | The address type requested is unknown or unsupported. |
| RSI_METHOD_UNSUPPORTED | This method is not supported in this version. |
| RSI_MOTION_DONE_WAIT_TIMEOUT | Timed out while waiting for MotionDone. |
| RSI_ERROR_MESSAGE_DYNAMIC | The text for this error will be dynamically generated in the source code. |
| RSI_NETWORK_FIRMWARE_IS_BUSY | The network firmware is busy. |
| RSI_CONTROLLER_INVALID_UNHANDLED | The controller is invalid due to prior failure. |
| RSI_STREAMING_OUTPUT_CONFIG_INVALID | The number of streaming output values must be configured with StreamingOutputCountSet before adding outputs. |
| RSI_AXIS_HOME_FAILED_TO_REACH_MAX_TRAVEL | Failed to reached State in specified Max Travel. Please evaluate limits or Stage's Max Travel value. |
| RSI_AXIS_HOME_UNEXPECTED_STATE | Expected STOPPED state but didn't reach it. Homing requires Home/Hardware Limit actions set to STOP. |
| RSI_AXIS_HOME_INVALID_POS_LIMIT_HIT | Hit Positive Limit while moving to Negative Limit. |
| RSI_AXIS_HOME_INVALID_NEG_LIMIT_HIT | Hit Negative Limit while moving to Positive Limit. |
| RSI_AXIS_LIMIT_UNEXPECTED_STATE | Expected True and was False or vise versa. |
| RSI_AXIS_RISING_HOME_STATE_HIGH_CHECK | Failed to reach expected Home State: High. This method should only be used for Home Setups which are High to the Positive Limit. |
| RSI_AXIS_RISING_HOME_STATE_LOW_CHECK | Failed to reach expected Home State: Low. This method should only be used for Home Setups which are High to the Positive Limit. |
| RSI_AXIS_FALLING_HOME_STATE_HIGH_CHECK | Failed to reach expected Home State: High. This method should only be used for Home Setups which are High to the Negative Limit. |
| RSI_AXIS_FALLING_HOME_STATE_LOW_CHECK | Failed to reach expected Home State: Low. This method should only be used for Home Setups which are High to the Negative Limit. |
| RSI_AXIS_HOME_INDEX_NOT_SUPPORTED | Home Methods which require Index are only selectively supported. Contact RSI to see if we can add support for your hardware. |
| RSI_AXIS_HOME_INDEX_NOT_REACHABLE | Distance to Travel to Index (AKDs Zero Angle) is greater than Home Stage Max Travel. Skipping Motion. Please evaluate your Stage Max Travel. |
| RSI_AXIS_HOME_INDEX_NOT_REACHED | Did not finish in IDLE state after attempting to move to Zero Angle. |
| RSI_NETWORK_NODE_DOES_NOT_EXIST | NetworkNode object does not exist. |
| RSI_COMPENSATOR_POINT_COUNT_INVALID | Memory allocated for compensator not equal to required. |
| RSI_COMPENSATOR_COULD_NOT_DISABLE_SINGLE | The compensator could not be disabled. |
| RSI_COMPENSATOR_COULD_NOT_ENABLE_ADDITIVE | The compensator could not be enabled. |
| RSI_COMPENSATOR_INVALID_AXIS_MASTER_TYPE | The compensator config was invalid. |
| RSI_COMPENSATOR_COULD_NOT_ENABLE_AXIS_ACTUAL_POSITION | The compensator could not be enabled. |
| RSI_IOPOINT_INVALID_OUTPUT | An output was configured as an input. |
| RSI_FIRMWARE_VERSION_MISMATCH | The RMP firmware and the RapidCode software versions don't match. Restart your INtime Node. |
| RSI_NOFEATURE_LICENSE | The RMP feature is not enabled. |
| RSI_GCODE_PARSE | Error interpreting the G-Code string. |
| RSI_GCODE | Generic type for RSI specific G-Code errors. |
| RSI_GCODE_LINE | Generic type for RSI specific G-Code errors occurring on a specific line or move. |
| RSI_GCODE_SYNTAX | G-Code Syntax parsing errors. |
| RSI_EXECUTOR | Exception while running the Cartesian trajectory executor. |
| RSI_CARTESIAN_TRAJECTORY_BUILDER | Error while trying to build the Cartesian trajectory before running it. |
| RSI_CARTESIAN_PATH | Cartesian move builder exception. |
| RSI_CARTESIAN_PATH_LINE | Cartesian move builder exception occurring on a specific line or move. |
| RSI_CARTESIAN_ROBOT | Robot errors. |
| RSINetworkNodeMessageNODE_FAILURE | EtherCAT node failure. |
| RSI_MATHBLOCK_INVALID | Invalid MathBlock. |
| RSI_AMP_ENABLE_RESTRICTED_STATE | Failed attempt to enable amplifier in a restricted state (MOVING, STOPPING, STOPPED) see RapidCodeMotion::AmpEnableSet(). |
Definition at line 17 of file rsienums.h.
