◆ ErrorLimitActionSet()
void ErrorLimitActionSet ( RSIAction action)
ErrorLimitActionSet sets the action that will occur when the Error Limit Event triggers.
actionAction taken on Error Limit trigger. A ::RSIAction value.
Note:
Axis: Configuration
// add phantom axis
// get phantom axis
Go to axis screen->Limits & Actions. In image below, ErrorLimitActionSet sets the action type shown in the Position Error box. It is currently set to ABORT.
  • Position Error = Command Position - Actual Position
  • For safety reasons, you may want to set this to ABORT event.
ErrorLimitActionGet
MultiaxisMotion.cpp, PVTmotionMultiAxis.cpp, PathMotion.cpp, SingleAxisSyncOutputs.cpp, SyncOutputWithMotion.cpp, UpdateBufferPoints.cpp, _helpers.cs, axis-config-phantom-axis.cs, axis-homing-akd-drive.cs, config.h, and phantom-axis.cpp.
