◆ CompensatorCountSet()
void CompensatorCountSet ( int32_t compensatorCount)
CompensatorCountSet sets the number of Compensators enabled on the controller. This must be configured before creating Axis or MultiAxis objects, as these object counts change the dynamic memory allocation inside the controller's firmware.
Motion: Compensator
const int INDEX_ZERO = 0;
const int INDEX_ONE = 1;
// print compensator info
// get rmp controller
// get & configure axes
// set compensator0
inputAxis: movingAxis,
inputAxisMinimum: MIN,
inputAxisMaximum: MAX,
inputAxisDelta: DELTA,
outputAxis: followerAxis,
table: table0);
// set compensator1
compensatorNumber: INDEX_ONE,
table: table1);
// get results
// print results
// verify compensation
const int AXIS_1_INDEX
Definition _constants.cs:21
Compensator output types.
Definition rsienums.h:1602
RSIAxisMasterType
Definition rsienums.h:1359
The firmware default is 0.
CompensatorCountGet, CompensatorPointCountSet
