◆ AnalogInGet()
int32_t AnalogInGet ( int32_t analogChannel)
AnalogInGet returns the value of an analog input. It is passed a starting channel ID relative to the Node (not Segment).
analogChannelThe analog input number on the node, starts from 0.
(int32_t) Value of the analog input.
Part of the IO Members method group.
📜 Velocity Motion via Analog Input
/* This sample demonstrates how to control axis velocity dynamically using an analog input value.
The analog input value (0 to 65536 for a 16-bit input) is mapped to a velocity range.
This was created using the EL3002 Analog Input module but works with many other modules.
using System.Threading;
Console.WriteLine("📜 Axis Motion: Velocity via Analog Input");
const double ACCELERATION = 100;
const double MAX_VEL = 10;
const double MAX_ANALOG = 65536; // 16-bit analog input
const int RUN_TIME_SECONDS = 20; // how long to run the velocity control loop
// get phantom axis
Axis axis = controller.AxisGet(Constants.AXIS_1_INDEX);
// get node
Helpers.CheckErrors(node);
// configure axis
// print sample info
Console.WriteLine($"Max Speed = {MAX_VEL}");
Console.WriteLine($"Running for {RUN_TIME_SECONDS} seconds...\n");
// control velocity based on analog input
var startTime = DateTime.Now;
while ((DateTime.Now - startTime).TotalSeconds < RUN_TIME_SECONDS)
// get analog input value and normalize to 0.0 - 1.0
double analogValue = node.AnalogInGet(analogChannel: 0);
double normalizedValue = analogValue / MAX_ANALOG;
│ Analog Input Value Maps Linearly to Velocity │
│ Analog: 0 ............................ 65,536 │
│ Velocity: 0 ............................ MAX_VEL │
// map analog input linearly to velocity (0 to MAX_VEL)
double velocity = normalizedValue * MAX_VEL;
axis.MoveVelocity(velocity, ACCELERATION);
Thread.Sleep(1); // prevent cpu spin
const int AXIS_1_INDEX
Definition _constants.cs:21
Definition rsienums.h:621
Slice I/O has multiple segments of same type (Digital/Analog In/Out) which are grouped together. The reference number for any channel of a given type
can be defined as when it is encounted relative to the Slice I/O Node or an individual Slice.
