◆ CreateAnalogInput()
static IOPoint * CreateAnalogInput ( NetworkNode * networkNode,
int32_t analogChannel )
static
networkNodeThe network node which has the analog input.
analogChannelThe analog channel number relative to the entire I/O node
(IOPoint*) A pointer to the newly created IOPoint.
Part of the IOPoint Creation method group.
IO: Input & Output
const int NODE_INDEX = 0; // The EtherCAT Node we will be communicating with
const int OUTPUT_INDEX = 0; // The PDO Index in that Node
IOPoint output0 = IOPoint.CreateDigitalOutput(controller.NetworkNodeGet(NODE_INDEX), OUTPUT_INDEX); // Automatically gets the memory index of a specified node and input index
output0.Set(false);
controller.SampleWait(1);
Assert.That(output0.Get(), Is.False, "The getter function should return a value equal to false");
