◆ MotionHoldUserAddressSet()
void MotionHoldUserAddressSet ( uint64_t address)
MotionHoldUserAddressSet sets the User Address which will be monitored before the motion hold is released.
addressThe host address that will be monitored for Motion Hold
Motion: Hold
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Definition rsi.h:6515
Set the motion hold type.
Definition rsienums.h:617
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
MotionHoldUserAddressGet(), MotionHoldTypeSet()
This value is not stored in Axis XML.
MotionHoldReleasedBySoftwareAddress.cpp, axis-motion-hold-via-address.cs, and axis-motion-hold-via-digitalinput.cs.
