◆ MoveRelative() [2/3]
void MoveRelative ( double relativePosition,
double vel,
double accel,
double decel,
double jerkPct )
MoveRelative command a relative point-to-point motion, with an S-Curve velocity profile. Axis will move relative increment distance from the currently commanded position.
S-Curve Velocity Profile
relativePositionA relative increment, positive or negative.
velMaximum velocity, UserUnits/second.
accelMaximum acceleration , UserUnits/second/second. (peak up to 2× accel when jerkPercent = 100, see below)
decelMaximum deceleration , UserUnits/second/second. (peak up to 2× decel when jerkPercent = 100, see below)
jerkPctJerk Percent, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0 .
Part of the Motion method group. See the S-Curve Motion concept page for more information.
RelativeMotion
axis.MoveRelative(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
// move back to start using negative relative motion
axis.MoveRelative(-POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
Motion Scope:
Relative move profile shown below:
Point to Point, MoveSCurve, MoveTrapezoidal, MoveVelocity, MovePT, MovePVT
MotionHoldReleasedBySoftwareAddress.cpp, axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, axis-motion-hold-via-position.cs, axis-motion-point-to-point.cs, camming.cs, difference-of-position-user-limit.cpp, mathblock-difference-of-position-userlimit.cs, and point-to-point.cpp.
