11.1.1
HardwareNegLimitActionSet()
void HardwareNegLimitActionSet
action
HardwareNegLimitActionSet sets the action that will occur when the Hardware Negative Limit Event triggers.
action
Action taken on Negative Limit trigger. A ::RSIAction value.
Note:
Available Actions are
Abort()
EStop()
Stop()
, None,
EStopAbort()
, and
EStopModify()
Axis: Configuration
bool
ACTIVE_HIGH =
true
bool
ACTIVE_LOW =
false
double
HW_POS_DURATION_TIME = 0.01;
// Positive limit duration (in seconds)
double
HW_NEG_DURATION_TIME = 0.01;
// Negative limit duration (in seconds)
// set pos & neg limits
axis.
HardwarePosLimitActionSet
.RSIActionE_STOP);
axis.
(ACTIVE_HIGH);
axis.
HardwarePosLimitDurationSet
(HW_POS_DURATION_TIME);
axis.
.RSIActionE_STOP);
axis.
(ACTIVE_LOW);
axis.
HardwareNegLimitDurationSet
(HW_NEG_DURATION_TIME);
// get pos & neg limits
hPosLimAct = axis.
HardwarePosLimitActionGet
bool
hPosLimTrigState = axis.
double
hPosLimDur = axis.
HardwarePosLimitDurationGet
hNegLimAct = axis.
HardwareNegLimitActionGet
bool
hNegLimTrigState = axis.
double
hNegLimDur = axis.
HardwareNegLimitDurationGet
Go to axis screen->Limits & Actions. In image below, HardwareNegLimitActionSet sets the action type shown in the Negative (-) Hardware box. It is currently set to E_STOP.
HardwareLimits.cpp
_helpers.cs
axis-config-phantom-axis.cs
axis-configuration.cpp
axis-homing-master-based.cs
config.h
, and
phantom-axis.cpp
1.15.0
