◆ HomeJerkPercentGet()
double HomeJerkPercentGet ( RSIHomeStage homeStage = RSIHomeStage::RSIHomeStageSTAGE_ONE)
HomeJerkPercentGet gets the jerk percent used for homing.
homeStageOptional (Default: RSIHomeStageSTAGE_ONE)
(double) percent (0.0 to 100.0)
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
Home
Master-based homing diagrams.
