Represents a single axis of motion control. This class provides an interface for commanding motion, reading trajectory parameters, homing, limit switch configuration, motor configuration, position capture, configuring filter (control law) parameters, electronic gearing and access to its NetworkNode. Get or create an Axis object using MotionController::AxisGet. More...
Functions
void MoveTrapezoidal (double position, double vel, double accel, double decel)
void MoveTrapezoidal (double position, double vel, double accel, double decel, double finalVel)
void MoveTrapezoidal (double position)
void MoveSCurve (double position, double vel, double accel, double decel, double jerkPct)
void MoveSCurve (double position)
 MoveSCurve with the Axis defaults trajectory values from DefaultVelocitySet, DefaultAccelerationSet, DefaultDecelerationSet, and DefaultJerkPercentSet
Note: DefaultAcceleration and Deceleration may be exceeded.
void MoveSCurve (double position, double vel, double accel, double decel, double jerkPct, double finalVel)
void MoveVelocity (double velocity)
void MoveVelocity (double velocity, double accel)
 Command a constant velocity move (jog).
void MoveVelocitySCurve (double velocity, double accel, double jerkPct)
 Command a constant velocity move (jog) with non-constant acceleration.
void MoveRelative (double relativePosition, double vel, double accel, double decel, double jerkPct)
void MoveRelative (double relativePosition)
void MoveRelative (double relativePosition, double vel, double accel, double decel, double jerkPct, double finalVel)
void PositionSet (double position)
double ActualPositionGet ()
void ActualPositionSet (double position)
 Set the actual position.
double CompensationPositionGet ()
 Get the compensator position.
void CompensationPositionSet (double position)
 Set the compensator position.
double TargetPositionGet ()
 Get the target position.
double CommandPositionGet ()
void CommandPositionSet (double position)
 Sets the value of the command and actual positions of an axis.
void CommandPositionDirectSet (double position)
 directly sets the value of the command position of an axis
double OriginPositionGet ()
 Get the origin position.
void OriginPositionSet (double position)
 Set the origin position.
double PositionErrorGet ()
 Get the current position error.
double CommandVelocityGet ()
 Get the current commanded velocity.
double ActualVelocityGet ()
 Get the current actual velocity.
double CommandAccelGet ()
 Get the current commanded acceleration.
double CommandJerkGet ()
 Get the current commanded jerk value (custom firmware required).
double EncoderPositionGet (RSIMotorFeedback encoder)
 Get the raw encoder position.
double UserUnitsGet ()
void UserUnitsSet (double countsPerUserUnit)
double UserUnitsToCounts (double userUnits)
 Convert from UserUnits to raw feedback counts.
double CountsToUserUnits (double counts)
 Convert from raw feedback counts to UserUnits.
int32_t FramesToExecuteGet ()
void Home (bool moveToZero=true)
 Execute the homing routine.
RSIHomeMethod HomeMethodGet ()
 Get the method to be used for homing.
void HomeMethodSet (RSIHomeMethod method)
double HomeOffsetGet ()
 Get the home offset.
void HomeOffsetSet (double offset)
double HomeVelocityGet (RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
 Get the home velocity.
void HomeVelocitySet (double velocity)
 Set the home velocity.
void HomeVelocitySet (RSIHomeStage homeStage, double velocity)
double HomeSlowVelocityGet ()
 Get the slow home velocity.
void HomeSlowVelocitySet (double velocity)
 Set the slow home velocity.
double HomeAccelerationGet (RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
 Get the deceleration used for homing.
void HomeAccelerationSet (double accel)
void HomeAccelerationSet (RSIHomeStage homeStage, double accel)
double HomeDecelerationGet (RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
 Get the decleration to be used for homing when using the switch is not detected before the HomeTravelDistanceSet() has been reached.
void HomeDecelerationSet (double decel)
 Set the decleration to be used for homing when using the switch is not detected before the HomeTravelDistanceSet() has been reached.
void HomeDecelerationSet (RSIHomeStage homeStage, double decel)
double HomeJerkPercentGet (RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
 Get the Jerk Percent used for homing.
void HomeJerkPercentSet (double percent)
 Set the Jerk Percent used for homing.
void HomeJerkPercentSet (RSIHomeStage homeStage, double percent)
void HomeCancelSet (bool cancel)
 Cancel Homing.
bool HomeStateGet ()
 Get the home state.
void HomeStateSet (bool homed)
 Set the home state.
void HomeLimitCustomConfigSet (uint64_t address, int32_t bitIndex)
void HomeLimitCustomConfigReset ()
 Remove any custom home input configuration and reset to use the Axis' dedicated home input bit.
uint64_t HomeLimitCustomConfigAddressGet ()
 Get the host address of the custom home input configuration.
int32_t HomeLimitCustomConfigBitIndexGet ()
void HomeTravelDistanceSet (RSIHomeStage stage, double distanceToTravel)
 Set the max travel used in a specific Homing Stage.
RSIHomeStage HomeStageGet ()
 Get the current Homing Stage.
void HomeBehaviorSet (RSIAction behavior)
 Set the Action used for Master based homing.
RSIAction HomeBehaviorGet ()
 Get the Action used during Master based Homing.
bool FaultMaskBitGet (RSIMotorFaultMask bitMask)
 Unsupported Function. Likely to be removed in the future.
uint16_t StatusWordGet ()
 Get the DS402 status word.
bool NegativeLimitGet ()
bool PositiveLimitGet ()
bool HomeLimitGet ()
 Get the current state of the Home limit.
bool HomeSwitchGet ()
bool AmpFaultGet ()
bool AmpEnableGet ()
bool DedicatedInExists (RSIMotorDedicatedIn motorDedicatedInNumber)
 Determine if a particular Dedicated input bit exists for a motor.
bool DedicatedOutExists (RSIMotorDedicatedOut motorDedicatedOutNumber)
 Determine if a particular Dedicated output bit exists for a motor.
bool DedicatedInGet (RSIMotorDedicatedIn motorDedicatedInNumber)
 Read a digital input.
uint32_t DedicatedInputsGet ()
 Get all 32 dedicated input bits at once for this axis.
bool DedicatedOutGet (RSIMotorDedicatedOut motorDedicatedOutNumber)
 Get the state of dedicated output bit.
uint32_t DedicatedOutputsGet ()
 Get all 32 dedicated output bits at once for this axis.
bool DigitalInGet (RSIMotorGeneralIo motorGeneralIoNumber)
uint32_t DigitalInputsGet ()
 Get all 32 digital input bits at once for this axis.
bool DigitalOutGet (RSIMotorGeneralIo motorGeneralIoNumber)
 Get the state of digital output bit.
uint32_t DigitalOutputsGet ()
 Get all 32 digital output bits at once for this axis.
void DigitalOutSet (RSIMotorGeneralIo motorGeneralIoNumber, bool outValue)
 Set a digital output bit.
bool DigitalIoExists (RSIMotorGeneralIo motorGeneralIoNumber)
 Determine if a particular General I/O bit exists for a motor.
const char *const DigitalIoNameGet (RSIMotorGeneralIo motorGeneralIoNumber)
 Get the name of a Motor I/O bit.
RSIMotorIoTypeMask DigitalIoValidTypesMaskGet (RSIMotorGeneralIo motorGeneralIoNumber)
 Get the type mask for a Motor I/O bit.
void DigitalIoTypeSet (RSIMotorGeneralIo motorGeneralIoNumber, RSIMotorIoType type)
 Set the type for a Motor I/O bit.
double AnalogInGet (int32_t channel)
double EStopDecelerationGet ()
void EStopDecelerationSet (double decel)
double EStopJerkPercentGet ()
 Get the jerk percent for an E-Stop, Modify Event.
void EStopJerkPercentSet (double jerkPct)
 Set the jerk percent for an E-Stop, Modify Event.
double TriggeredModifyDecelerationGet ()
 Get the deceleration rate for an Triggered Modify Event.
void TriggeredModifyDecelerationSet (double decel)
double TriggeredModifyJerkPercentGet ()
 Get the jerk percent for an Triggered Modify Event.
void TriggeredModifyJerkPercentSet (double jerkPct)
int32_t FrameBufferSizeGet ()
void FrameBufferSizeSet (int32_t frameSize)
uint16_t MotionIdExecutingGet ()
uint16_t MotionElementIdExecutingGet ()
double MotionFinalVelocityGet ()
 Get final velocity of a motion, when FINAL_VEL motion attribute is used.
void MotionFinalVelocitySet (double finalVelocity)
 Set the final velocity of a motion, when FINAL_VEL motion attribute is used.
double DefaultVelocityGet ()
 Get the default velocity in UserUnits.
void DefaultVelocitySet (double velocity)
 Set the default velocity in UserUnits.
double DefaultAccelerationGet ()
 Get the default acceleration in UserUnits.
void DefaultAccelerationSet (double acceleration)
double DefaultDecelerationGet ()
 Get the default deceleration in UserUnits.
void DefaultDecelerationSet (double deceleration)
double DefaultJerkPercentGet ()
 Get the default jerk percent.
void DefaultJerkPercentSet (double jerkPercent)
 Set the default jerk percent.
double DefaultPosition1Get ()
 Get the default Position 1 value in UserUnits (used by RapidSetup).
void DefaultPosition1Set (double position1)
 Set the default Position 1 value in UserUnits (used by RapidSetup).
double DefaultPosition2Get ()
 Get the default Position 2 value in UserUnits (used by RapidSetup).
void DefaultPosition2Set (double position2)
 Set the default Position 2 value in UserUnits (used by RapidSetup).
double DefaultRelativeIncrementGet ()
 Get the default relative increment value in UserUnits (used by RapidSetup).
void DefaultRelativeIncrementSet (double relativeIncrement)
 Set the default relative value in UserUnits (used by RapidSetup).
RSIAction AmpFaultActionGet ()
 Get the Amp Fault action.
void AmpFaultActionSet (RSIAction action)
 Set the Amp Fault action.
bool AmpFaultTriggerStateGet ()
void AmpFaultTriggerStateSet (bool state)
double AmpFaultDurationGet ()
void AmpFaultDurationSet (double seconds)
int32_t AmpFaultTriggerSampleGet ()
 Get the controller sample at which the Amp Fault condition most recently became true.
RSIAction HomeActionGet ()
 Get the action that will occur when the Home LIMIT triggers.
void HomeActionSet (RSIAction action)
bool HomeTriggerStateGet ()
 Get the trigger state for the Home input.
void HomeTriggerStateSet (bool state)
 Set the trigger state for the Home input.
double HomeDurationGet ()
 Get the duration required before the Home event triggers.
void HomeDurationSet (double seconds)
 Set the duration required before the Home event triggers.
RSIAction ErrorLimitActionGet ()
 Get the action that will occur when the Position Error Limit Event triggers.
void ErrorLimitActionSet (RSIAction action)
double ErrorLimitTriggerValueGet ()
 Get the Position Error Limit trigger value.
void ErrorLimitTriggerValueSet (double triggerValue)
double ErrorLimitDurationGet ()
 Get the duration required before the Position Error Limit event triggers.
void ErrorLimitDurationSet (double seconds)
 Sets the duration required before the Position Error Limit event triggers.
int32_t ErrorLimitTriggerSampleGet ()
 Get the controller sample at which the Position Error Limit condition most recently became true.
RSIAction HardwareNegLimitActionGet ()
void HardwareNegLimitActionSet (RSIAction action)
bool HardwareNegLimitTriggerStateGet ()
 Trigger state return.
void HardwareNegLimitTriggerStateSet (bool state)
 Sets the trigger state.
double HardwareNegLimitDurationGet ()
void HardwareNegLimitDurationSet (double seconds)
int32_t HardwareNegLimitTriggerSampleGet ()
 Get the controller sample at which the Hardware Negative Limit condition most recently became true.
RSIAction HardwarePosLimitActionGet ()
void HardwarePosLimitActionSet (RSIAction action)
bool HardwarePosLimitTriggerStateGet ()
 trigger state return.
void HardwarePosLimitTriggerStateSet (bool state)
 sets the trigger state.
double HardwarePosLimitDurationGet ()
void HardwarePosLimitDurationSet (double seconds)
int32_t HardwarePosLimitTriggerSampleGet ()
 Get the controller sample at which the Hardware Positive Limit condition most recently became true.
RSIAction SoftwareNegLimitActionGet ()
 Get the action that will occur when the Software Negative Limit Event triggers.
void SoftwareNegLimitActionSet (RSIAction action)
double SoftwareNegLimitTriggerValueGet ()
 Get the Software Negative Position limit.
void SoftwareNegLimitTriggerValueSet (double triggerValue)
 Set the Software Negative Position limit.
int32_t SoftwareNegLimitTriggerSampleGet ()
 Get the controller sample at which the Software Negative Limit condition most recently became true.
RSIAction SoftwarePosLimitActionGet ()
 Get the action that will occur when the Software Positive Limit Event triggers.
void SoftwarePosLimitActionSet (RSIAction action)
double SoftwarePosLimitTriggerValueGet ()
 Get the Software Positive Position limit.
void SoftwarePosLimitTriggerValueSet (double triggerValue)
 Set the Software Positive Position limit.
int32_t SoftwarePosLimitTriggerSampleGet ()
 Get the controller sample at which the Software Positive Limit condition most recently became true.
RSIAction EncoderFaultActionGet ()
 Get the action that will occur when the Encoder Fault Limit Event triggers.
void EncoderFaultActionSet (RSIAction action)
 Set the action that will occur when the Encoder Fault Limit Event triggers.
RSIMotorFeedbackFault EncoderFaultTriggerGet ()
 Get the encoders which are used to generate encoder faults.
void EncoderFaultTriggerSet (RSIMotorFeedbackFault encoder)
 Set the encoders which are used to generate encoder faults.
double EncoderFaultDurationGet ()
 Get the duration required before the Encoder Fault Limit event triggers.
void EncoderFaultDurationSet (double seconds)
 Set the duration required before the Encoder Fault Limit event triggers.
int32_t EncoderFaultTriggerSampleGet ()
 Get the controller sample at which the Encoder Fault condition most recently became true.
RSIAction NodeFailureActionGet ()
 Get the action for a node failure.
void NodeFailureActionSet (RSIAction action)
 Set the action for a node failure.
RSIAction SyncGroupFaultActionGet ()
 Get the action taken when this Axis's node's EtherCAT sync group faults.
void SyncGroupFaultActionSet (RSIAction action)
 Set the action taken when this Axis's node's EtherCAT sync group faults.
uint64_t AddressGet (RSIAxisAddressType addressType)
RSIDataType AddressDataTypeGet (RSIAxisAddressType type)
RSIAction LimitActionGet (RSIEventType limit)
 Get the action for any type of limit.
void LimitActionSet (RSIEventType limit, RSIAction action)
 Set the action for any type of limit.
bool LimitTriggerStateGet (RSIEventType limit)
 Get the trigger state for any type of limit.
void LimitTriggerStateSet (RSIEventType limit, bool triggerState)
 Set the trigger state for any type of limit.
double LimitTriggerValueGet (RSIEventType limit)
 Get the trigger value for any type of limit.
void LimitTriggerValueSet (RSIEventType limit, double triggerValue)
 Set the trigger value for any type of limit.
double LimitDurationGet (RSIEventType limit)
 Get the duration for any type of limit.
void LimitDurationSet (RSIEventType limit, double seconds)
 Set the duration for any type of limit.
double PositionToleranceFineGet ()
void PositionToleranceFineSet (double tolerance)
double PositionToleranceCoarseGet ()
void PositionToleranceCoarseSet (double tolerance)
double VelocityToleranceGet ()
void VelocityToleranceSet (double tolerance)
double SettlingTimeGet ()
 Get the Settling time.
void SettlingTimeSet (double time)
 Set the settling time.
bool SettleOnStopGet ()
 Get the Stop Event settling configuration.
void SettleOnStopSet (bool state)
 Set the Stop Event settling configuration.
bool SettleOnEStopGet ()
 Get the E-Stop Event settling configuration.
void SettleOnEStopSet (bool state)
 Set the E-Stop Event settling configuration.
bool SettleOnEStopCmdEqActGet ()
 Get the E-Stop Event settling configuration when E-Stop is configured for (Command = Actual).
void SettleOnEStopCmdEqActSet (bool state)
 Set the settling configuration for E-Stop events (when configured for Command = Actual).
RSIMotorType MotorTypeGet ()
 Get the motor type.
void MotorTypeSet (RSIMotorType type)
 Set the motor type.
RSIMotorDisableAction AmpDisableActionGet ()
 Get the Amp Disable action.
void AmpDisableActionSet (RSIMotorDisableAction action)
 Set the Amp Disable action.
RSIMotorBrakeMode BrakeModeGet ()
 Get the brake mode.
void BrakeModeSet (RSIMotorBrakeMode mode)
 Set the brake mode.
double BrakeApplyDelayGet ()
 Get the delay time for the brake to be applied.
void BrakeApplyDelaySet (double seconds)
 Set the brake apply delay.
double BrakeReleaseDelayGet ()
 Get the brake release delay time.
void BrakeReleaseDelaySet (double seconds)
 Set the Brake Release Delay.
void ClosedLoopStepperSet (bool enable)
 Unsupported.
int32_t ClosedLoopStepperVersionGet ()
 Unsupported.
uint64_t EncoderPointerGet (RSIMotorFeedback encoder)
 Get the pointer (host address) for the motor feedback.
void EncoderPointerSet (RSIMotorFeedback encoder, uint64_t address)
 Set the pointer (host address) for the motor feedback.
uint64_t FeedbackDeltaPointerGet (RSIAxisPositionInput input)
 Get the pointer (host address) for the axis feedback.
void FeedbackDeltaPointerSet (RSIAxisPositionInput input, uint64_t address)
 Set the pointer (host address) for the axis feedback.
uint64_t FeedbackPointerGet (RSIAxisPositionInput input)
void FeedbackPointerSet (RSIAxisPositionInput input, uint64_t address)
 Configure an axis for dual loop feedback.
int32_t EncoderRatioNumeratorGet (RSIMotorFeedback encoder)
 Get the encoder ratio numerator.
int32_t EncoderRatioDenominatorGet (RSIMotorFeedback encoder)
 Get the encoder ration denominator.
void EncoderRatioSet (RSIMotorFeedback encoder, int32_t numerator, int32_t denominator)
 Sets the ratio to scale Encoder counts.
const char *const EncoderRatioPrimaryGet ()
 Get the primary feedback encoder ratio as text.
void EncoderRatioPrimarySet (char *numeratorCommaDenominator)
 Set the primary feedback encoder ratio as text. "1.0 ,2.0".
const char *const EncoderRatioSecondaryGet ()
 Get the secondary feedback encoder ratio as text.
void EncoderRatioSecondarySet (char *numeratorCommaDenominator)
 Set the secondary feedback encoder ratio as text. "1.0 ,2.0".
int32_t EncoderCountGet ()
 Get the number of encoders processed in firmware by the motor object. Valid values: 0,1,2.
void EncoderCountSet (int32_t count)
RSIAxisGantryType GantryTypeGet ()
 Get the gantry type.
void GantryTypeSet (RSIAxisGantryType type)
 Set the gantry type.
RSIOperationMode OperationModeGet ()
 Get the operation mode.
void OperationModeSet (RSIOperationMode mode)
 Set the axis operation mode.
int32_t MotorFaultMaskGet ()
 Get the Motor Fault Mask.
void MotorFaultMaskSet (int32_t faultMask)
 Set the Motor Fault Mask.
void GearingEnable (int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, int32_t numerator, int32_t denominator)
void GearingEnable (Axis *masterAxis, RSIAxisMasterType masterFeedbackSource, int32_t numerator, int32_t denominator)
 Enable this Axis to be a follower (slave) using electronic gearing. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
void GearingRatioChange (int32_t numerator, int32_t denominator)
 Change the electronic gearing ratio.
void GearingDisable ()
 Disable the electronic gearing.
int32_t GearingNumeratorGet ()
 Get the numerator of the gearing ratio.
int32_t GearingDenominatorGet ()
 Get the denominator of the gearing ratio.
bool GearingEnableGet ()
 Get the state of the gearing feature. If true, this Axis is a geared slave.
int32_t GearingMasterAxisNumberGet ()
 Get a Slave's Master Axis Number.
RSIAxisMasterType GearingSourceGet ()
 Get the Source used to slave to the Master Axis.
double MotionCamMasterStartGet (Axis *master)
 Gets the position on the master that will start the cam when exceeded.
void MotionCamMasterStartSet (Axis *master, double startPosition)
 Set the position at which camming starts.
int32_t MotionCamRepeatFromGet ()
 Get the segment at which camming repeats.
void MotionCamRepeatFromSet (int32_t repeatFrom)
 Set the segment at which camming repeats.
void MotionCamRepeatStop ()
 Stops a Repeating Cam.
void MoveCamLinear (int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, const double *const masterDistances, const double *const slavePositions, int32_t pointCount)
void MoveCamCubic (int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, const double *const masterDistances, const double *const slavePositions, const double *const gearRatios, int32_t pointCount)
 Enable this Axis to be cubic follower (slave) using an electronic cam.
int32_t DriveIndexGet ()
 Get the drive index, relative to the Network Node (multi-axis drives).
double BacklashWidthGet ()
 Gets the Backlash Width which was set by the user.
void BacklashWidthSet (double width)
 Sets the total range of the give in a system with Backlash.
double BacklashRateGet ()
 Gets the Backlash Rate which was set by the user.
void BacklashRateSet (double rate)
 Sets the rate at which Backlash is applied.
double BacklashValueGet ()
 Gets the current backlash compensation value.
RSIFilterAlgorithm FilterAlgorithmGet ()
 Get the control algorithm type for an axis.
void FilterAlgorithmSet (RSIFilterAlgorithm algorithm)
 Set the algorithm type for an axis.
double FilterCoeffGet (RSIFilterGainPIDCoeff coeff, int32_t gainTable)
 Get value for a filter coefficient (ex: Kp, Ki, Kd, etc).
void FilterCoeffSet (RSIFilterGainPIDCoeff coeff, int32_t gainTable, double coeffValue)
 Set a filter coefficient (ex: Kp, Ki, Kd).
double FilterCoeffGet (RSIFilterGainPIVCoeff coeff, int32_t gainTable)
void FilterCoeffSet (RSIFilterGainPIVCoeff coeff, int32_t gainTable, double coeffValue)
int32_t FilterGainTableGet ()
 Gets which gain table is currently in use by the axis.
void FilterGainTableSet (int32_t gainTable)
 Set the gain table to be used by an axis.
int32_t FilterGainTableSizeGet ()
 Gets the size of gain tables.
double FilterOutputGet (void)
 Get the output of a demand filter, range is +/- 100.0.
double FilterLowPassGet ()
 Get the value of the Low-Pass filter.
void FilterLowPassSet (double frequency)
 Use a Low-Pass filter.
void FilterDualLoopSet (Axis *velocityAxis, RSIMotorFeedback velocityEncoder, bool enable)
bool FilterGainSchedulingGet ()
 Get the status of automatic gain scheduling.
void FilterGainSchedulingSet (bool enable)
 Enable or disable automatic gain scheduling.
bool IsTuneable ()
 Is an Axis tunable? Returns false if Axis is in position mode, otherwise true.
void PostFilterLowPassSet (int32_t sectionNumber, double frequency)
void PostFilterUnityGainSet (int32_t sectionNumber)
 Use a Unity Gain Post Filter.
void PostFilterSingleOrderSet (int32_t sectionNumber, double aOne, double bZero, double bOne)
 Use a Single Order Post Filter.
void PostFilterHighPassSet (int32_t sectionNumber, double cornerFreq)
 Use a High Pass Post Filter.
void PostFilterNotchSet (int32_t sectionNumber, double centerFreq, double bandwidth)
 Use a Notch Post Filter.
void PostFilterResonatorSet (int32_t sectionNumber, double centerFreq, double bandwidth, double gain)
 Use a Resonator Post Filter.
void PostFilterLeadLagSet (int32_t sectionNumber, double lowGain, double highGain, double centerFreq)
 Use a Lead Lag Post Filter.
void PostFilterClear (int32_t sectionNumber)
 Remove any Post Filters in section Number.
void PostFilterBiquadSet (int32_t sectionNumber, double aOne, double aTwo, double bZero, double bOne, double bTwo)
 Use a Digital Biquad Post Filter.
const char *const PostFilterInfoGet ()
 Get a text description of the current post filters.
const char *const UserLabelGet ()
 Get the axis User defined Label.
void UserLabelSet (const char *const userLabel)
void PostTrajectoryGearingEnableSet (bool enable)
 Enable or disable post-trajectory gearing for this axis.
bool PostTrajectoryGearingEnableGet ()
 Get the enable state of post-trajectory gearing.
void PostTrajectoryGearingMasterAxisSet (int32_t masterAxisNumber)
 Set the master axis for post-trajectory gearing.
int32_t PostTrajectoryGearingMasterAxisGet ()
 Get the master axis number used for post-trajectory gearing.
void PostTrajectoryGearingMultiplierSet (double multiplier)
 Set the multiplier for post-trajectory gearing.
double PostTrajectoryGearingMultiplierGet ()
 Get the multiplier for post-trajectory gearing.
double PostTrajectoryGearingScaledOffsetGet ()
 Get the current scaled position offset from post-trajectory gearing.
uint32_t NetworkIndexGet (RSINetworkIndexType indexType)
void NetworkIndexSet (RSINetworkIndexType indexType, uint32_t newIndex)
 Override the PDO array index for an axis signal mapping.
double BacklashHysteresisLimitGet ()
 Get the backlash hysteresis limit.
void BacklashHysteresisLimitSet (double hysteresisLimit)
 Brief.
bool StepperMotorLoopbackGet ()
 Determine if the stepper is open or closed loop.
void StepperMotorLoopbackSet (bool loopback)
 Configure the stepper to be open or closed loop.
RSIMotorStepperPulseType StepperMotorPulseTypeGet (RSIMotorStepperPulse pulse)
 Determine how the stepper pulse outputs are configured.
void StepperMotorPulseTypeSet (RSIMotorStepperPulse pulse, RSIMotorStepperPulseType type)
 Set how the stepper pulse outputs are configured.
uint64_t GearingMasterAddressGet ()
 Get the address of the gearing master.
int32_t NumberGet ()
 Get the axis number.
int32_t AxisCountGet ()
 Get the axis count.
void TriggeredModify ()
 Modify the currently executing motion to decelerate the Axis or MultiAxis to a zero velocity IDLE state.
void Stop ()
 Stop an axis.
void Resume ()
 Resume an axis.
void EStop ()
 E-Stop an axis.
void EStopAbort ()
 E-Stop, then abort an axis.
void EStopModify ()
 E-Stop with a deceleration rate.
void EStopModifyAbort ()
void Abort ()
void ClearFaults ()
int32_t AmpEnableSet (bool enable, int32_t ampActiveTimeoutMilliseconds=AmpEnableTimeoutMillisecondsDefault, bool overrideRestrictedState=false)
void Map ()
 Writes the axis mapping relationship to the Controller.
void Unmap ()
 Removes the axis mapping relationship of the MultiAxis.
bool IsMapped ()
 Check to see if the axis mapping is active on the firmware.
void FeedRateSet (double rate)
double FeedRateGet ()
 Get the axis feed rate.
RSIState StateGet ()
RSISource SourceGet ()
const char *const SourceNameGet (RSISource source)
int32_t MotionDoneWait (int32_t waitTimeoutMilliseconds=WaitForever)
bool MotionDoneGet ()
bool StatusBitGet (RSIEventType bitMask)
uint64_t StatusBitsGet ()
 Return all the RMP firmware status bits as a 64-bit unsigned bitmask.
void InterruptWake ()
 Wake all threads waiting for an interrupt on this Axis.
double StopTimeGet ()
void StopTimeSet (double seconds)
double EStopTimeGet ()
void EStopTimeSet (double seconds)
double MotionDelayGet ()
 Get the delay (seconds) that will occur before motion starts.
void MotionDelaySet (double seconds)
 Set the time (seconds) that a motion will wait before starting.
uint16_t MotionIdGet ()
 Get the motion identifier.
void MotionIdSet (uint16_t id)
 Set the Motion identifier.
RSIMotionHoldType MotionHoldTypeGet ()
 Get the motion hold attribute type.
void MotionHoldTypeSet (RSIMotionHoldType type)
 Set the motion hold type.
int32_t MotionHoldGateNumberGet ()
 Returns the Motion Hold Gate number that the axis or multiaxis is set to.
void MotionHoldGateNumberSet (int32_t gateNumber)
 Assigns the axis or multiaxis Motion Hold Gate number to the specified controller gate.
double MotionHoldTimeoutGet ()
 Get the motion hold timeout value.
void MotionHoldTimeoutSet (double seconds)
 Set the motion hold timeout value.
bool MotionHoldGateGet ()
void MotionHoldGateSet (bool hold)
 Set the Motion Hold Gate.
int32_t MotionHoldAxisNumberGet ()
 Gets the Axis number.
void MotionHoldAxisNumberSet (int32_t number)
double MotionHoldAxisPositionGet ()
 Gets the Axis position.
void MotionHoldAxisPositionSet (double position)
 Sets the Axis position.
RSIUserLimitLogic MotionHoldAxisLogicGet ()
 Get the logic when holding for Axis ActualPosition.
void MotionHoldAxisLogicSet (RSIUserLimitLogic logic)
uint64_t MotionHoldUserAddressGet ()
 Gets the Motion Hold User Address.
void MotionHoldUserAddressSet (uint64_t address)
int32_t MotionHoldUserMaskGet ()
 Gets the Motion Hold User Mask.
void MotionHoldUserMaskSet (int32_t holdMask)
int32_t MotionHoldUserPatternGet ()
 Gets the Motion Hold user bit pattern.
void MotionHoldUserPatternSet (int32_t pattern)
void MotionAttributeMaskDefaultSet ()
 Restore the motion attribute mask to the RapidCode default.
bool MotionAttributeMaskOnGet (RSIMotionAttrMask maskOn)
 Check to see if a particular motion attribute mask is turned on.
void MotionAttributeMaskOnSet (RSIMotionAttrMask maskOn)
void MotionAttributeMaskOffSet (RSIMotionAttrMask maskOff)
void MovePT (RSIMotionType type, const double *const position, const double *const time, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
void MovePVT (const double *const position, const double *const velocity, const double *const time, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
void MovePVAJT (const double *const position, const double *const velocity, const double *const acceleration, const double *const jerk, const double *const time, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
void MovePTF (const double *const position, const double *const time, const double *const feedforward, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
 A move commanded by a list of position, time, and feedforward points.
void MovePVTF (const double *const position, const double *const velocity, const double *const time, const double *const feedforward, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
 Move commanded by list of positions, velocities, times, and feedforward values.
void StreamingOutputAdd (int32_t onMask, int32_t offMask, uint64_t address)
void StreamingOutputAdd (int32_t onMask, int32_t offMask, uint64_t address, int32_t ptPointIndex)
 Applies the on and off bitmasks to the controller's memory address when the motion reaches the specified streaming point index. Used to toggle Digital Outputs and/or memory.
void StreamingOutputAdd (RapidCode::IOPoint *point, bool on)
void StreamingOutputAdd (RapidCode::IOPoint *point, bool on, int32_t ptPointIndex)
 Sets the state of the specified IOPoint when the motion reaches the specified streaming point index.
void StreamingOutputsClear ()
void StreamingOutputsEnableSet (bool enable)
void InterruptMaskClear ()
void InterruptMaskAllSet ()
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Attributes
NetworkNode * NetworkNode
MotionController * rsiControl
Static Attributes
static constexpr int32_t AmpEnableTimeoutMillisecondsDefault = 500
 Default timeout in milliseconds for AmpEnableSet() to wait for AMP_ACTIVE / OPERATION_ENABLED to go high.
static constexpr int32_t WaitForever = -1
 Use this value to wait indefinitely in methods which accept a waitTimeoutMilliseconds parameter.
static constexpr uint32_t NetworkIndexInvalid = 65535
 Returned by NetworkIndexGet() when the index is invalid or nonexistent for this Axis.
static constexpr double AmpEnableAmpFaultTimeoutSecondsDefault = 1.0
 Default time an Axis waits before generating an AmpFault if the Axis does not enable after calling AmpEnableSet(true).
Description
Gantry.cpp, HardwareLimits.cpp, Memory.cpp, MotionHoldReleasedBySoftwareAddress.cpp, MultiaxisMotion.cpp, PVTmotionMultiAxis.cpp, PathMotion.cpp, SingleAxisSyncOutputs.cpp, SyncOutputWithMotion.cpp, UpdateBufferPoints.cpp, _helpers.cs, _setup.cs, axis-config-ampfault.cs, axis-config-hardware-limits.cs, axis-config-phantom-axis.cs, axis-config-settling.cs, axis-config-stop-rate.cs, axis-config-userunits.cs, axis-configuration.cpp, axis-homing-akd-drive.cs, axis-homing-ds402-drive.cs, axis-homing-master-based.cs, axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, axis-motion-hold-via-position.cs, axis-motion-modify.cs, axis-motion-point-to-point.cs, axis-motion-streaming-pt-whilestopping.cs, axis-motion-streaming-pt.cs, axis-motion-streaming-pvajt.cs, axis-motion-streaming-pvt.cs, axis-motion-velocity-via-analoginput.cs, axis-status.cs, basic-template.cs, calculate-acceleration-from-velocity.cpp, camming.cs, compensator-1d.cs, compensator-2d.cs, compensator-single-axis.cs, config.h, difference-of-position-user-limit.cpp, error-logs.cs, follow-sensor.cpp, gcode-motion.cs, gcode-units.cs, gearing.cs, io-dedicated.cs, io-sync-outputs.cs, mathblock-calculate-acceleration-from-velocity.cs, mathblock-difference-of-position-userlimit.cs, mathblock-pdo-copy.cs, multiaxis-motion-point-to-point.cs, multiaxis-motion-velocity.cs, path-3d-points.cs, path-motion.cs, path-setup-gantry.cs, phantom-axis.cpp, point-to-point.cpp, recorder.cs, rttaskglobals.h, touch-probe.cs, userlimit-command-position-direct.cs, userlimit-estop-store-position.cs, userlimit-feedrate.cs, and userlimit-position-abort.cs.
Definition at line 7047 of file rsi.h.
