◆ MotionCountSet()
void MotionCountSet ( int32_t motionCount)
MotionCountSet will configure the number of Motion Supervisors processed by the controller firmware .
motionCountThe Motion Supervisor count.
Part of the Information method group.
Motion: Multi-Axis
/* This sample demonstrates both trapezoidal and S-curve point-to-point motion profiles for multi-axis motion.
The MultiAxis object coordinates the motion of multiple axes simultaneously.
Console.WriteLine("📜 MultiAxis Motion: Point to Point");
Console.WriteLine($"Axis Count: {controller.AxisCountGet()}");
Helpers.VerifyAxisCount(controller, minRequiredSampleAxisCount: 2, minRequiredSampleMultiAxisCount: 1);
// get axes
Helpers.CheckErrors(axis0);
Helpers.CheckErrors(axis1);
// get multiaxis (indexed by motion supervisor number, indexing starts at 0)
Helpers.CheckErrors(multi);
// remove any existing axes
multi.AxisRemoveAll();
// add axes to multiaxis
multi.AxisAdd(axis0);
multi.AxisAdd(axis1);
// Use MotionAttributeMaskOnSet and MotionAttributeMaskOffSet to enable/disable synchronization features
// Both SYNC_START and SYNC_END are enabled by default
// See our Motion: Point-to-Point documentation for more details
// multi.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskSYNC_START);
// multi.MotionAttributeMaskOffSet(RSIMotionAttrMask.RSIMotionAttrMaskSYNC_END);
// prepare for motion
multi.Abort(); // stop any existing motion
multi.ClearFaults();
// Reset axes and position
axis0.PositionSet(0);
axis1.PositionSet(0);
// define motion parameters
double[] positions1 = [ 5, 10 ]; // first set of positions
double[] positions2 = [ 15, 15 ]; // second set of positions
double[] velocities1 = [ 10, 10 ]; // velocities for first move
double[] velocities2 = [ 10, 10 ]; // velocities for second move
double[] accelerations = [ 20, 20 ]; // accelerations for both axes
double[] decelerations = [ 20, 20 ]; // decelerations for both axes
double[] jerkPercent = [ 50, 50 ]; // jerk percent for s-curve motion
// move using s-curve motion profile
Console.WriteLine($"\nMove 1 (S-Curve): Positions = [{positions1[0]}, {positions1[1]}]");
multi.MoveSCurve(positions1, velocities1, accelerations, decelerations, jerkPercent);
multi.MotionDoneWait(); // wait for motion to complete
Console.WriteLine($"Axis 0 CommandPosition: {axis0.CommandPositionGet()} (expected: {positions1[0]})");
Console.WriteLine($"Axis 1 CommandPosition: {axis1.CommandPositionGet()} (expected: {positions1[1]})");
// move using trapezoidal motion profile
Console.WriteLine($"\nMove 2 (Trapezoidal): Positions = [{positions2[0]}, {positions2[1]}]");
multi.MoveTrapezoidal(positions2, velocities2, accelerations, decelerations);
Console.WriteLine($"Axis 0 CommandPosition: {axis0.CommandPositionGet()} (expected: {positions2[0]})");
Console.WriteLine($"Axis 1 CommandPosition: {axis1.CommandPositionGet()} (expected: {positions2[1]})");
Helpers.AbortMotionObject(multi);
Console.WriteLine("\nMulti-axis point-to-point motion complete.");
const int AXIS_1_INDEX
Definition _constants.cs:21
void AxisRemoveAll()
Point-to-point S-Curve Move.
void AxisAdd(Axis *axis)
Definition rsi.h:12226
MotionCountGet
