◆ UserLimitConditionSet() [2/2]
void UserLimitConditionSet ( int32_t number,
int32_t conditionNumber,
RSIUserLimitLogic logic,
uint64_t addressOfUInt32,
uint32_t userLimitMask,
uint32_t limitValueUInt32 )
UserLimitConditionSet set one of the conditions for a User Limit.
numberThe index of the UserLimit. Starts from 0 and goes to (UserLimitCountGet - 1).
conditionNumberThis should be 0 or 1, User Limits only support two conditions.
logicUse ::RSIUserLimitLogic
*addressOfUInt32Use any address in the controller (see sample code).
userLimitMaskA 32-bit AND mask, the limit ANDs the value stored in address with this mask.
limitValueUInt3232-bit value to be compared with the value stored in address after it is ANDed with the mask.
IO: User Limits
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
output0.Set(false);
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
Logic evaluates as follows: VALUE_AT_ADDRESS RSIUserLimitLogic LIMIT_VALUE' E.g. A limit with logic RSIUserLimitLogic.RSIUserLimitLogicGT Would be true when 'VALUE_AT_ADDRESS > LIMIT_VALUE'.
Be sure to user the correct overload of UserLimitConditionSet depending on if you have a 64-bit double or 32-bit integer trigger value.
UserLimitConfigSet , UserLimitOutputSet
