11.1.0
MotionHoldGateSet()
void MotionHoldGateSet
bool
hold
MotionHoldGateSet sets the state of the Motion Hold Gate.
hold
True = gate is set, motion execution will be prevented. false = gate is not set, motion will execute.
Motion Configuration
// hold motion (prevent from executing)
axis->MotionHoldGateSet(
true
MotionHoldGateGet
By default, an
or
MultiAxis
will use a gate number which matches its number. Keep in mind there are only 32 hold gates, so if your
or
MultiAxis
number is greater than 31, you must adjust using MotionHoldGateNumberSet
UpdateBufferPoints.cpp
RapidCodeMotion
1.15.0
