◆ MultiAxisGet()
MultiAxis * MultiAxisGet ( int32_t motionSupervisorNumber)
motionSupervisorNumberA motion supervisor index, should be >= AxisCount.
(MultiAxis*) A pointer to the MultiAxis specified.
This method is no longer recommended. Prefer the use of MotionController::LoadExistingMultiAxis()
You'll need to set the number of MotionSupervisors to a number greater than the Axis count. This should be done before any calls to AxisGet(), MultiAxisGet() or LoadExistingMultiAxis().
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
MultiAxis::AxisAdd , MotionCountGet , MotionCountSet
