The RMP assigns a logical number to each axis as it encounters them during network initialization. The first axis is 0, the second 1, and so on. This logical sequential number is the axisNumber passed to AxisGet.
Getting the Axis will cause all of its internal default values and low-level objects to be recreated.
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
