Namespaces | |
| namespace | Cartesian |
| The Cartesian namespace. | |
| namespace | RealTimeTasks |
| The RealTimeTasks namespace. | |
Classes | |
| class | Axis |
| Represents a single axis of motion control. This class provides an interface for commanding motion, reading trajectory parameters, homing, limit switch configuration, motor configuration, position capture, configuring filter (control law) parameters, electronic gearing and access to its NetworkNode. Get or create an Axis object using MotionController::AxisGet. More... | |
| union | FirmwareValue |
| Union representing a generic RMP firmware value with multiple data types, stored in 64-bits. More... | |
| class | IO |
| The IO object provides an interface to the inputs and outputs of a network node. More... | |
| class | IOPoint |
| Represents one specific point: Digital Output, Digital Input, Analog Output, or Analog Input. This class provides a helper interface to any I/O, regardless of where it resides: MotionController, Axis, or NetworkNode. To create an IOPoint, use IOPoint Creation Methods. More... | |
| class | MotionController |
| Represents the RMP soft motion controller. This class provides an interface to general controller configuration, firmware upload/download, network, user limits and data recording. To make a MotionController object, use MotionController creation methods.. More... | |
| class | MultiAxis |
| Represents multiple axes of motion control, allows you to map two or more Axis objects together for error propagation and commanding coordinated, synchronized motion. Create a MultiAxis object on the controller and get it using MotionController::LoadExistingMultiAxis. More... | |
| class | NetworkNode |
| Represents an EtherCAT node / SubDevice (Drive, I/O Block, etc) on the network. This class provides an interface to all digital and analog I/O on the node, as well as the ability to read and write SDOs. Get or create a NetworkNode using MotionController::NetworkNodeGet or the Axis property, NetworkNode. More... | |
| class | RapidCodeInterrupt |
| Interface for objects which can use interrupts. More... | |
| class | RapidCodeMotion |
| The RapidCodeMotion interface is implemented by Axis and MultiAxis . More... | |
| class | RapidCodeObject |
| The RapidCode base class. All non-error objects are derived from this class. More... | |
| class | RapidCodeOS |
| The RapidCodeOS object provides access to operating system (Windows) features. Accessible via MotionController . More... | |
| class | RapidVector |
| A wrapper class for the C++ STL vector class that aims to maintain application binary interface. Provides some of the basic vector operations (with RapidCode naming conventions). More... | |
| class | RsiError |
| Represents the error details thrown as an exception by all RapidCode classes. This class contains an error number/type, RSIErrorMessage, and a text message which describes the error. Throwing exceptions can be disabled on all RSI classes. If throwing exceptions is disabled, a log of RsiErrors can be accessed. Inherits from std::exception in C++ and System.Exception in C#. More... | |
| class | RTOS |
| Represents the real-time operating system (INtime) when using RMP for Windows. This class provides static methods to start, stop, and restart INtime. More... | |
| class | Trace |
| Tracing allows for low level logs to be generated. More... | |
Enumerations | |
| enum class | INtimeStatus |
| INtime status values. More... | |
| enum class | RSIAction |
| Action to perform on an Axis. More... | |
| enum class | RSIAnalogOutChannel |
| Analog output channels. More... | |
| enum class | RSIAxisAddressType |
| Used to get firmware address used in User Limits, Recorders, etc. More... | |
| enum class | RSIAxisGantryType |
| How to combine Axis Feedback Positions. More... | |
| enum class | RSIAxisMasterType |
| Sources available to a slave Axis for electronic gearing & camming. More... | |
| enum class | RSIAxisPositionInput |
| Feedback Positions for each Axis. More... | |
| enum class | RSICacheObject |
| Caching data for GUI optimization. More... | |
| enum class | RSICompensatorOutputType |
| Compensator output types. More... | |
| enum class | RSIControllerAddressType |
| enum class | RSIControllerType |
| Controller type. More... | |
| enum class | RSIDataType |
| Data types for User Limits and other triggers. More... | |
| enum class | RSIErrorMessage |
| All possible RSI Error Messages. More... | |
| enum class | RSIEventType |
| Event Types or Status Bits. More... | |
| enum class | RSIFilterAlgorithm |
| Filter algorithms. More... | |
| enum class | RSIFilterGainIndex |
| Filter Gain Table enums for. More... | |
| enum class | RSIFilterGainPIDCoeff |
| PID gain coefficients. More... | |
| enum class | RSIFilterGainPIVCoeff |
| PIV gain coefficients. More... | |
| enum class | RSIFirmwareLogic |
| Logic options for User Limits. More... | |
| enum class | RSIFirmwareStatus |
| Firmware status bit masks for the axis status word. More... | |
| enum class | RSIHomeMethod |
| enum class | RSIHomeStage |
| Predefined Homing Stage sections. More... | |
| enum class | RSIMathBlockOperation |
| MathBlock operations. More... | |
| enum class | RSIMotionAttrMask |
| Attribute masks for motion. You cannot mix RSIMotionAttrMaskDELAY and RSIMotionAttrMaskAPPEND. More... | |
| enum class | RSIMotionAttrOutputType |
| Types for outputs during motion. More... | |
| enum class | RSIMotionHoldType |
| Types for MotionHold attribute. More... | |
| enum class | RSIMotionType |
| PT and PVT streaming motion types. More... | |
| enum class | RSIMotorBrakeMode |
| Brake modes. More... | |
| enum class | RSIMotorDedicatedIn |
| Dedicated Input bits per motor. More... | |
| enum class | RSIMotorDedicatedOut |
| Dedicated Output bits per motor. More... | |
| enum class | RSIMotorDisableAction |
| Action for when a motor is disabled. More... | |
| enum class | RSIMotorFaultMask |
| Mask values for several motor faults. More... | |
| enum class | RSIMotorFeedback |
| Encoders per motor. More... | |
| enum class | RSIMotorFeedbackFault |
| Feedbacks to use for Feedback Fault action. More... | |
| enum class | RSIMotorGeneralIo |
| Motor I/O bit numbers. More... | |
| enum class | RSIMotorIoType |
| Possible configurations for Motor I/O. More... | |
| enum class | RSIMotorIoTypeMask |
| Possible mask bits for Motor I/O types. More... | |
| enum class | RSIMotorLimitType |
| Motor Limits. More... | |
| enum class | RSIMotorStepperPulse |
| Pulse A or B. More... | |
| enum class | RSIMotorStepperPulseType |
| Stepper pulse type. More... | |
| enum class | RSIMotorType |
| Motor Type. More... | |
| enum class | RSIMultiAxisAddressType |
| enum | RSINetworkEniResult |
| NetworkEniGenerate return values. More... | |
| enum class | RSINetworkIndexType |
| Network PDO index types for configuring axis input/output mappings. More... | |
| enum class | RSINetworkInterfaceType |
| Network host interface type used for EtherCAT frame I/O. More... | |
| enum class | RSINetworkNodeAddressType |
| Address types for the dynamic status values of an EtherCAT node, for use with RapidCodeNetworkNode::AddressGet. More... | |
| enum class | RSINetworkNodeInitializationState |
| How far an EtherCAT node has progressed through network startup. More... | |
| enum class | RSINetworkOutputAddressType |
| Network output address types. More... | |
| enum class | RSINetworkStartError |
| Network start errors. More... | |
| enum class | RSINetworkStartMode |
| Network start modes. More... | |
| enum class | RSINetworkStartupMethod |
| Network startup methods. More... | |
| enum class | RSINetworkState |
| State of network. More... | |
| enum class | RSINetworkSyncGroupState |
| State of an EtherCAT sync group (a set of nodes sharing one WKC-tolerant cyclic datagram). More... | |
| enum class | RSINetworkTechnologyType |
| Network technology type. More... | |
| enum class | RSINetworkType |
| Type of Network topology. More... | |
| enum class | RSINodeType : uint64_t |
| Valid Node types. More... | |
| enum class | RSIOperationMode |
| DS402 modes of operation. More... | |
| enum class | RSIPathPlanType |
| Path motion planning types. More... | |
| enum class | RSIPDOType |
| enum class | RSIProcessorType |
| Controller's processor type. More... | |
| enum class | RSISource |
| Possible sources that have caused an Error state. More... | |
| enum class | RSIState |
| enum class | RSITrace |
| Trace masks. More... | |
| enum class | RSIUserLimitLogic |
| enum class | RSIUserLimitTriggerType |
| Trigger types for UserLimits. More... | |
| enum class | RSIWait |
| Waiting for interrupts. More... | |
