◆ SourceNameGet()
const char *const SourceNameGet ( RSISource source)
SourceNameGet will return the first status bit which is set on an Axis or MultiAxis. The source can be checked when in an error state. There may be additional status bits set, use StatusBitGet to check any other bits.
source(::RSISource)
(char*) The name of the ::RSISource.
Part of the State and Status method group.
Axis Status
/* This sample application demonstrates how to read the status of an axis using the RapidCode .NET API.
It checks the current state of the axis and identifies any error sources if the axis is not operating normally.
Additionally, it shows how to check specific status bits for conditions such as amplifier faults and limit switches.
Console.WriteLine("📜 Axis: Status");
// get state
RSIState state = axis.StateGet();
Console.WriteLine($"Your Axis is in state: {state}");
switch (state)
case RSIState.RSIStateIDLE:
case RSIState.RSIStateMOVING:
case RSIState.RSIStateERROR:
case RSIState.RSIStateSTOPPING_ERROR:
case RSIState.RSIStateSTOPPED:
case RSIState.RSIStateSTOPPING:
RSISource source = axis.SourceGet(); // get state source enum
Console.WriteLine($"The source of the axis error is: {axis.SourceNameGet(source)}"); // get first status bit set on this axis
default:
Console.WriteLine("Axis is in an unexpected state.");
// get some RSIEventTypes status bits
bool isAmpFaultActive = axis.StatusBitGet(RSIEventType.RSIEventTypeAMP_FAULT);
bool isPosErrLimActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_ERROR);
bool isHwNegLimActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_HW_NEG);
bool isHwPosLimActive = axis.StatusBitGet(RSIEventType.RSIEventTypeLIMIT_HW_POS);
Console.WriteLine($"Amp Fault Active: {isAmpFaultActive}");
Console.WriteLine($"Position Error Limit Active: {isPosErrLimActive}");
Console.WriteLine($"HW Negative Limit Active: {isHwNegLimActive}");
Console.WriteLine($"HW Positive Limit Active: {isHwPosLimActive}");
Definition rsi.h:6515
RSIState StateGet()
RSISource SourceGet()
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1045
RSISource
Definition rsienums.h:1094
Go to Axis screen, Status tab.
This displays the various bits that are checked if axis is in error state
::RSISource, StateGet
