◆ Create() [2/2]
MotionController * Create ( CreationParameters * creationParameters)
static
Description: Create a MotionController object. This will start the RMP firmware if it is not already running.
It will open and map in the existing firmware if it is running.
creationParametersThe set of parameters used to create a MotionController object, and start an RMP firmware if it is not already running. See MotionController::CreationParameters for parameter documentation
This is the only creation method available for Linux.
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
SyncInterrupt.cpp, _setup.cs, axis-configuration.cpp, basic-template.cs, calculate-acceleration-from-velocity.cpp, difference-of-position-user-limit.cpp, follow-sensor.cpp, hello-rttasks.cpp, phantom-axis.cpp, point-to-point.cpp, print-network-topology.cpp, record-performance.cpp, and starter-template.cpp.
