| void MovePTF | ( | const double *const | position, |
| const double *const | time, | ||
| const double *const | feedforward, | ||
| int32_t | pointCount, | ||
| int32_t | emptyCount, | ||
| bool | retain, | ||
| bool | final ) |
| *position | Array of positions (p) to move through. (positions are in the UserUnits for each Axis) Axis: [p0, p1, p2, ..., pn] MultiAxis, assuming the Axis mapping is J0, J1, J2: [J0p0, J1p0, J2p0, ..., J0pn, J1pn, J2pn] |
| *time | Array of time durations for each point in seconds. Minimum value is your MotionController sample period. Values must be a multiple of the sample period. If each point should take one millisecond, your array would be: [0.001, 0.001, 0.001, etc.] |
| *feedforward | Array of feedforward values (f) to apply. (commonly scaled to 16-bit or 32-bit integer values) Axis: [f0, f1, f2, ..., fn] MultiAxis, assuming the Axis mapping is J0, J1, J2: [J0f0, J1f0, J2f0, ..., J0fn, J1fn, J2fn] |
| pointCount | The number of position/time/feedforward points. |
| emptyCount | The number of motion frames (2 per point) that must be in the RMP firmware's buffer, below which triggers an OUT_OF_FRAMES E-Stop action. The RapidCode library will load frames to the RMP firmware automatically, when the buffer gets low (1/4 of the MotionController::AxisFrameBufferSizeSet() value). Set emptyCount high enough such that the duration of frames (2 per point) are greater than the value of EStopTimeGet/Set(). emptyCount must also be smaller than 20% of the MotionController::AxisFrameBufferSizeSet() value. Using a value of 0 or -1 will result in undefined motion behavior if the firmware frame buffer is starved. |
| retain | Points kept, or not kept (must be True if you attempt a negative feedrate to back up on path). |
| final | True if this is the final streaming motion call, False if more streaming motion calls will occur before this call's points are finished. |
