◆ MoveSCurve() [2/3]
void MoveSCurve ( const double *const position,
const double *const vel,
const double *const accel,
const double *const decel,
const double *const jerkPct )
MoveSCurve calls a point-to-point S-Curve velocity profile move.
*positionArray of target positions (in UserUnits for each Axis).
*velArray of velocities (UserUnits/second).
*accelArray of average accelerations (UserUnits/second/second). (peak up to 2× accel when jerkPercent = 100, see below)
*decelArray of average decelerations (UserUnits). (peak up to 2× decel when jerkPercent = 100, see below)
*jerkPctArray of jerk percents, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0
// Assume 2 axes.
double positions[2] = {1000.0, 2000.0};
double velocities[2] = {1000.0, 1000.0};
double accels[2] = {10000.0, 10000.0};
double decels[2] = {10000.0, 10000.0};
double jerkPcts[2] = {50.0, 25.0};
multiAxis->MoveSCurve(positions, velocities, accels, decels, jerkPcts);
MotionAttributeMaskGet
MultiaxisMotion.cpp, and multiaxis-motion-point-to-point.cs.
