◆ Home()
void Home ( bool moveToZero = true)
Home executes the homing routine as configured with the other homing methods. At the completion of finding the index / marker pulse, or the desired switch, the Axis will set the Home Offset, and then move to the zero position. If you don't want the Axis to move to zero after homing, set "moveToZero" false.
moveToZeroSet true if you want the Axis to move to zero at the end of homing. (Default: true)
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
Notes:
Be sure to set Home Action to ::RSIActionSTOP. Also set HW Positive/Negative Limit actions to STOP if homing with limit switches.
HomeMethodSet, HomeOffsetSet, HomeVelocitySet, HomeAccelerationSet, HomeDecelerationSet, HomeActionSet
Master-based homing.
PathMotion.cpp, and axis-homing-master-based.cs.
