◆ MoveRelative() [3/3]
void MoveRelative ( double relativePosition,
double vel,
double accel,
double decel,
double jerkPct,
double finalVel )
MoveRelative with a final velocity. Command a relative point-to-point S-Curve motion.
MoveRelative command a relative point-to-point motion, with an S-Curve velocity profile. Axis will move relative increment distance from the currently commanded position.
S-Curve Velocity Profile
relativePositionA relative increment, positive or negative.
velMaximum velocity, UserUnits/second.
accelMaximum acceleration , UserUnits/second/second. (peak up to 2× accel when jerkPercent = 100, see below)
decelMaximum deceleration , UserUnits/second/second. (peak up to 2× decel when jerkPercent = 100, see below)
jerkPctJerk Percent, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0 .
Part of the Motion method group. See the S-Curve Motion concept page for more information.
RelativeMotion
axis.MoveRelative(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
// move back to start using negative relative motion
axis.MoveRelative(-POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
Motion Scope:
Relative move profile shown below:
Point to Point, MoveSCurve, MoveTrapezoidal, MoveVelocity, MovePT, MovePVT
finalVelVelocity the Axis will follow after completing the rest of the profile.
