◆ RecorderCountGet()
int32_t RecorderCountGet ( )
RecorderCountGet returns the number of Recorder enabled on the controller.
(int32_t) The Recorder count.
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12981
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
The firmware default is 0.
RecorderCountSet
