◆ GearingEnable() [2/2]
void GearingEnable ( int32_t masterAxisNumber,
RSIAxisMasterType masterFeedbackSource,
int32_t numerator,
int32_t denominator )
GearingEnable enables this Axis to be follower (slave) using electronic gearing.
masterAxisNumberAn index that represents the master axis.
masterFeedbackSourceA ::RSIAxisMasterType value.
numeratorMultiple of counts that slave follows relative to master.
denominatorDivisor of counts that slave follows relative to master.
Part of the Gearing method group.
/* This sample demonstrates how to configure electronic gearing between two axes.
The follower axis position is controlled as a ratio of the moving axis position.
Moving Axis: the master axis that drives the motion.
Follower Axis: follows the moving axis at a specified gear ratio.
See the Gearing concept page (Concepts > Motion > Gearing) for how the follower's command is formed
and how moves and stopping actions on the follower behave.
Console.WriteLine("📜 Gearing");
const int NUMERATOR = 2; // for every 1 rotation of moving axis...
const int DENOMINATOR = 1; // ...follower axis rotates 2 times (2:1 ratio)
const double POSITION = 10;
const double VELOCITY = 10;
const double ACCELERATION = 100;
const double DECELERATION = 100;
// get axes
Axis movingAxis = controller.AxisGet(Constants.AXIS_0_INDEX);
Axis followerAxis = controller.AxisGet(Constants.AXIS_1_INDEX);
// configure phantom axes
// enable phantoms to keep commanded position after motion done
followerAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// configure follower axis to gear to moving axis
followerAxis.GearingEnable(
masterAxisNumber: movingAxis.NumberGet(),
masterFeedbackSource: RSIAxisMasterType.RSIAxisMasterTypeAXIS_COMMAND_POSITION, // use COMMAND for phantoms, ACTUAL for real axis
numerator: NUMERATOR,
denominator: DENOMINATOR);
// perform s-curve motion on moving axis
movingAxis.MoveSCurve(POSITION, VELOCITY, ACCELERATION, DECELERATION, JERK_PERCENT);
movingAxis.MotionDoneWait();
// print results
Console.WriteLine($"Moving axis final position: {movingAxis.CommandPositionGet()}");
Console.WriteLine($"Follower axis final position: {followerAxis.CommandPositionGet()}");
Console.WriteLine($"Gear ratio: {NUMERATOR}:{DENOMINATOR}");
// disable gearing
followerAxis.GearingDisable();
const int AXIS_1_INDEX
Definition _constants.cs:21
void GearingDisable()
Disable the electronic gearing.
void GearingEnable(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, int32_t numerator, int32_t denominator)
int32_t NumberGet()
Get the axis number.
RSIAxisMasterType
Definition rsienums.h:1359
Notes:
The gearing ratio will be numerator/denominator. Every sample the firmware adds the master's scaled position change to this Axis's command position, on top of any motion of this Axis's own. A move commanded on a geared Axis superimposes on the gearing and completes at its target plus the master's scaled movement since the move was commanded; to move to an absolute position, call GearingDisable first. Stop, TriggeredModify and the EStop variants end this Axis's own move but not the gearing; only GearingDisable or an Abort variant, which disables the amplifier, ends the following.
Gearing, GearingRatioChange, GearingDisable
gearing.cs.
