◆ HomeSlowVelocityGet()
double HomeSlowVelocityGet ( )
HomeSlowVelocityGet gets the velocity used for final (Stage Three) homing. Moving from Edge to Index.
(double) velocity units/second.
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
Deprecated. Use HomeVelocityGet(RSIHomeStageSTAGE_THREE) instead.
