MotionController::MathBlockConfig
MathBlock configuration structure. More...
Attributes
uint64_t InputAddress0
uint64_t InputAddress1
RSIDataType InputDataType0
RSIDataType InputDataType1
RSIMathBlockOperation Operation
 Math operation to be performed. (+, -, *, /, etc) use RSIMathBlockOperationNONE to disable a MathBlock.
uint64_t OutputAddress
 Host memory address for Output. The MathBlock will write its result to this address. (optional) Set to 0 or RSIControllerAddressTypeFIRMWARE_NULL_OUTPUT to disable.
RSIDataType OutputDataType
 Data type for Output. (optional).
RSIDataType ProcessDataType
 Data type for processing.
Description
MathBlock configuration structure. Use this structure to configure a MathBlock. Each MathBlock has two inputs, a process value and an output.
MathBlockConfigGet, MathBlockConfigSet
calculate-acceleration-from-velocity.cpp, and difference-of-position-user-limit.cpp.
Definition at line 4352 of file rsi.h.
