◆ MotionAttributeMaskOffSet()
void MotionAttributeMaskOffSet ( RSIMotionAttrMask maskOff)
MotionAttributeMaskOffSet turns off a particular motion attribute mask.
maskOffRSIMotionAttrMask value we want to turn off.
Motion: Hold
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Definition rsi.h:6515
Set the motion hold type.
Definition rsienums.h:617
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
::RSIMotionAttrMask, MotionAttributeMaskOnGet, MotionAttributeMaskOnSet
MotionHoldReleasedBySoftwareAddress.cpp, axis-motion-hold-via-address.cs, and axis-motion-hold-via-digitalinput.cs.
