◆ HomeDecelerationGet() [1/2]
double HomeDecelerationGet ( )
The only situation HomeDeceleration is used is if the maximum homing travel is exceeded and a switch is never hit. StopTimeSet() is used for the pos/neg limit switch.
(double) decel units/second/second.
Axis: Homing
// get rmp controller
return;
Axis axis = controller.AxisGet(axisNumber: 0);
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Set the home velocity.
void Home()
Execute the homing routine.
bool HomeStateGet()
Get the home state.
Definition rsi.h:5863
Definition rsienums.h:568
Definition rsienums.h:1116
Home
Master-based homing diagrams.
