mathblock-pdo-copy.cs
See IO: Math Blocks 📜 for a detailed explanation of this sample code.
/* This sample app demonstrates configuring a MathBlock to copy a PDO value from one axis to another with a bias offset.
This sample app requires at least 2 real Axis so that PDOs can be read and written.
Console.WriteLine("📜 MathBlock: PDO Copy");
const int MB_INDEX = 0;
const int BIAS = 8000;
const RSIDataType INT32 = RSIDataType.RSIDataTypeINT32;
const RSIMathBlockOperation ADD = RSIMathBlockOperation.RSIMathBlockOperationADD;
// get RMP controller
// set mathblock count before any RapidCodeObject get/create other than the controller
controller.MathBlockCountSet(1);
// get & configure axis 0
Helpers.CheckErrors(axis0);
// get & configure axis 1
Helpers.CheckErrors(axis1);
// check axis are real and not phantom
if (!axis0.NetworkNode.Exists() || !axis1.NetworkNode.Exists())
Console.WriteLine("One or both axes are phantom (not real). Please use real axes for this sample app.");
// write BIAS value to user buffer index 0
// if you want a dynamic bias, you can write to this address at any time or use the process value of another MathBlock instead
ulong userBufferAddr0 = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0);
controller.MemorySet(userBufferAddr0, BIAS);
// configure the MathBlock to copy a PDO value from axis 0 to a PDO override value on axis 1 with a BIAS offset
// here we are using the actual torque of axis 0 and the target torque of axis 1, but these can be replaced with whatever PDOs you want
// by changing the index values to the desired PDOs
uint torqueActualIndex = axis0.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeTORQUE_ACTUAL_INDEX);
ulong torqueActualAddress = controller.NetworkInputAddressGet((int)torqueActualIndex);
uint targetTorqueIndex = axis1.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeTARGET_TORQUE_INDEX);
ulong targetTorqueAddress = controller.NetworkOutputAddressGet((int)targetTorqueIndex, RSINetworkOutputAddressType.RSINetworkOutputAddressTypeOVERRIDE_VALUE);
// enable the network override to copy the MathBlock output to the PDO
// only needs to be set once, probably in initialization
controller.NetworkOutputOverrideSet((int)targetTorqueIndex, true);
// MathBlock config & set (mb.value = axis0.torqueActual + BIAS)
var mbConfig = controller.MathBlockConfigGet(MB_INDEX);
mbConfig.InputAddress0 = torqueActualAddress; // input0: axis 0 actual torque
mbConfig.InputAddress1 = userBufferAddr0; // input1: BIAS from user buffer
mbConfig.InputDataType0 = INT32;
mbConfig.InputDataType1 = INT32;
mbConfig.Operation = ADD; // switch to MULTIPLY for proportional bias
mbConfig.ProcessDataType = INT32;
mbConfig.OutputAddress = targetTorqueAddress; // output: axis 1 target torque override
mbConfig.OutputDataType = INT32;
// set MathBlock and wait 1 sample for config to take effect
controller.MathBlockConfigSet(MB_INDEX, mbConfig);
controller.SampleWait(1);
// print results
Console.WriteLine($"MathBlock configured to copy axis {Constants.AXIS_0_INDEX} torque actual to axis {Constants.AXIS_1_INDEX} target torque with bias {BIAS}");
Console.WriteLine($"Operation: {mbConfig.Operation}");
Console.WriteLine("✅ MathBlock PDO copy with bias configured successfully");
const int AXIS_1_INDEX
Definition _constants.cs:21
NetworkNode * NetworkNode
Definition rsi.h:7077
bool Exists()
Returns true if this NetworkNode exists on a physical network.
MathBlock operations.
Definition rsienums.h:1614
Definition rsienums.h:621
RSIDataType
Definition rsienums.h:784
Network output address types.
Definition rsienums.h:1595
RSINetworkIndexType
Definition rsienums.h:1573
