_helpers.cs
See ⚙️ Helpers 📜 for a detailed explanation of this sample code.
public static class Helpers
public static void CheckErrors(RapidCodeObject rsiObject)
var hasErrors = false;
var errorStrBuilder = new System.Text.StringBuilder();
while (rsiObject.ErrorLogCountGet() > 0)
// get error
RsiError rsiError = rsiObject.ErrorLogGet();
// get message
var errorMsg = rsiError.isWarning ? $"WARNING: {rsiError.Message}" : $"ERROR: {rsiError.Message}";
errorStrBuilder.AppendLine(errorMsg);
// set flag
hasErrors = !rsiError.isWarning;
if (hasErrors)
throw new Exception(errorStrBuilder.ToString());
public static void NetworkStart(MotionController controller)
// check if network is started already
Console.WriteLine("Starting Network..");
// if not started, initialize the network
controller.NetworkStart();
// check if network is started again
RSINetworkStartError startError = controller.LastNetworkStartErrorGet();
Console.WriteLine($"Network start error: {startError} ({(int)startError})");
// read network log messages
int messagesToRead = controller.NetworkLogMessageCountGet();
// print all the messages to help figure out the problem
Console.WriteLine(controller.NetworkLogMessageGet(i));
throw new SystemException("Expected OPERATIONAL state but the network did not get there.");
Console.WriteLine("Network Started");
public static void NetworkShutdown(MotionController controller)
// check if the network is already shutdown
if (controller.NetworkStateGet() == RSINetworkState.RSINetworkStateUNINITIALIZED ||
controller.NetworkStateGet() == RSINetworkState.RSINetworkStateSHUTDOWN)
return;
// shutdown the network
Console.WriteLine("Shutting down the network..");
controller.NetworkShutdown();
// check if the network is shutdown
var networkState = controller.NetworkStateGet();
if (networkState != RSINetworkState.RSINetworkStateUNINITIALIZED &&
networkState != RSINetworkState.RSINetworkStateSHUTDOWN)
// some kind of error shutting down the network, read the network log messages
throw new SystemException("Expected SHUTDOWN state but the network did not get there.");
Console.WriteLine("Network Shutdown");
public static void ControllerSetup(MotionController controller)
NetworkShutdown(controller);
// reset the controller to ensure it is in a known state
controller.Reset();
NetworkStart(controller);
public static void PhantomAxisReset(Axis phantomAxis)
if (phantomAxis.MotorTypeGet() != RSIMotorType.RSIMotorTypePHANTOM)
throw new Exception(@$"Axis {phantomAxis.NumberGet()} is not configured as a phantom axis.
Please ensure the axis is set to phantom before calling PhantomAxisConfigure.");
// abort any motion
AbortMotionObject(phantomAxis);
phantomAxis.ErrorLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.HardwareNegLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.HardwarePosLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.HomeActionSet(RSIAction.RSIActionNONE);
phantomAxis.SoftwareNegLimitActionSet(RSIAction.RSIActionNONE);
phantomAxis.SoftwarePosLimitActionSet(RSIAction.RSIActionNONE);
// set position tolerances to max value for immediate MotionDone
phantomAxis.PositionToleranceCoarseSet(POSITION_TOLERANCE_MAX);
phantomAxis.PositionToleranceFineSet(POSITION_TOLERANCE_MAX);
// set sample apps default motion parameters
phantomAxis.UserUnitsSet(1);
phantomAxis.DefaultVelocitySet(100);
phantomAxis.DefaultAccelerationSet(1000);
phantomAxis.DefaultDecelerationSet(1000);
phantomAxis.DefaultJerkPercentSet(0);
phantomAxis.PositionSet(0);
public static void AbortMotionObject(RapidCodeMotion motionObject)
motionObject.EStopAbort();
motionObject.MotionDoneWait();
motionObject.ClearFaults();
// check for idle state
if (motionObject.StateGet() != RSIState.RSIStateIDLE)
RSISource source = motionObject.SourceGet(); // get state source enum
string errorMsg = @$"Axis or MultiAxis {motionObject.NumberGet()} failed to enter IDLE state after aborting.
The source of the axis error is: {motionObject.SourceNameGet(source)}";
throw new Exception(errorMsg);
@brief Ensures relationship between USE_HARDWARE constant and network status and throws if mismatch found.
@param controller Pointer to the MotionController to check.
@exception Exception Thrown if mismatch found between USE_HARDWARE constant and network status, or user cancels on warning.
@par Code Snippet
@snippet _helpers.cs VerifyHardwareUsage
public static void VerifyHardwareUsage(MotionController controller)
const bool USE_HARDWARE = Constants.USE_HARDWARE; // User must set this in _constants.cs
bool networkIsOperational = controller.NetworkStateGet() == RSINetworkState.RSINetworkStateOPERATIONAL;
if (USE_HARDWARE && !networkIsOperational)
throw new Exception("USE_HARDWARE is set to true, but the network is not operational. " +
"Please properly configure your hardware or run _setup.cs.");
else if (!USE_HARDWARE && networkIsOperational)
throw new Exception("USE_HARDWARE is set to false, but the network is operational. " +
"Please ensure you are not connected to real hardware, or set USE_HARDWARE in _constants.cs to true.");
else if (!USE_HARDWARE && !networkIsOperational)
Console.WriteLine("Running with phantom axes as expected.");
// State running with hardware and require 'y' input from user to continue or any other key to abort
Console.WriteLine("Caution: You are currently running with hardware. " +
"Do not continue unless you have configured your axes through _setup.cs or another tool!");
Console.Write("Press 'y' to continue: ");
var input = Console.ReadKey();
Console.WriteLine(); // Move to next line after key press
if (input.KeyChar != 'y' && input.KeyChar != 'Y')
throw new Exception("User chose not to continue with hardware operation.");
@brief Verifies that the AXIS_COUNT constant matches the controller's axis count, then validates minimum axis and MultiAxis requirements. Outputs comparison information to console.
@param controller The MotionController object to verify.
@param minRequiredSampleAxisCount Minimum number of axes required by the sample application (default: 1).
@param minRequiredSampleMultiAxisCount Minimum number of MultiAxis objects required by the sample application (default: 0).
@exception Exception Thrown if AXIS_COUNT doesn't match controller axis count, if minimum axis count is not met, or if minimum MultiAxis count (calculated as MotionCount minus AxisCount) is not met.
@par Code Snippet
@snippet _helpers.cs VerifyAxisCount
public static void VerifyAxisCount(MotionController controller, int minRequiredSampleAxisCount = 1, int minRequiredSampleMultiAxisCount = 0)
int controllerAxisCount = controller.AxisCountGet();
int AXIS_COUNT = Constants.AXIS_COUNT;
// Verify AXIS_COUNT matches controller AxisCountGet()
if (controllerAxisCount != AXIS_COUNT)
// Axis count mismatch. Throw exception to stop execution
throw new Exception($"Controller axis count ({controllerAxisCount}) does not match intended AXIS_COUNT ({AXIS_COUNT}). " +
"Please ensure AXIS_COUNT in _constants.cs matches your number of hardware axes, then run _setup.cs or another tool " +
"to configure your hardware.");
// Verify minimum axis count
// Check against AXIS_COUNT here because if we get here we know controllerAxisCount == AXIS_COUNT
if (AXIS_COUNT < minRequiredSampleAxisCount)
throw new Exception($"This sample requires at least {minRequiredSampleAxisCount} " +
$"{(minRequiredSampleAxisCount == 1 ? "axis" : "axes")}, but AXIS_COUNT is only {AXIS_COUNT}. " +
$"Update your AXIS_COUNT in _constants.cs to meet the minimum requirement.");
// Verify minimum MultiAxis count
if (controller.MotionCountGet() - controllerAxisCount < minRequiredSampleMultiAxisCount)
throw new Exception($"This sample requires at least {minRequiredSampleMultiAxisCount} " +
$"MultiAxis object{(minRequiredSampleMultiAxisCount == 1 ? "" : "s")}. " +
"Please add more motion supervisors.");
const int AXIS_COUNT
Default: 6.
Definition _constants.cs:14
RSIMotorType MotorTypeGet()
Get the motor type.
void DefaultVelocitySet(double velocity)
Set the default velocity in UserUnits.
void DefaultJerkPercentSet(double jerkPercent)
Set the default jerk percent.
RSIState StateGet()
RSISource SourceGet()
void EStopAbort()
E-Stop, then abort an axis.
The RapidCodeMotion interface is implemented by Axis and MultiAxis .
Definition rsi.h:5505
int32_t ErrorLogCountGet()
Definition rsi.h:180
Definition rsi.h:111
bool isWarning
Definition rsi.h:120
Definition rsienums.h:621
Definition rsienums.h:1256
RSIMotorType
Motor Type.
Definition rsienums.h:1452
Network start errors.
Definition rsienums.h:715
RSISource
Definition rsienums.h:1151
Definition helpers.h:87
[CheckErrors]
Definition helpers.h:128
void NetworkShutdown(MotionController *controller)
[NetworkStart]
Definition helpers.h:167
