mathblock-calculate-acceleration-from-velocity.cs
See IO: Math Blocks 📜 for a detailed explanation of this sample code.
/* This sample app demonstrates configuring MathBlocks to calculate acceleration from velocity.
It uses one MathBlock to subtract the previous velocity from the current velocity to get the velocity delta,
and a second MathBlock to store the current velocity as the previous velocity for the next calculation.
The calculated acceleration is then derived from the velocity delta and sample rate.
Console.WriteLine("📜 MathBlock: Calculate Acceleration from Velocity");
const int MB_COUNT = 2;
const int MB1 = 0; // mathblock 1 index: subtract current velocity - previous velocity
const int MB2 = 1; // mathblock 2 index: store current velocity as previous velocity
const double VELOCITY = 1.0;
const double ACCELERATION = 0.0123;
const RSIDataType DOUBLE = RSIDataType.RSIDataTypeDOUBLE;
const RSIMathBlockOperation SUBTRACT = RSIMathBlockOperation.RSIMathBlockOperationSUBTRACT;
const RSIMathBlockOperation MULTIPLY = RSIMathBlockOperation.RSIMathBlockOperationMULTIPLY;
// get RMP controller
// set mathblock count before any RapidCodeObject get/create other than the controller
controller.MathBlockCountSet(MB_COUNT);
// get & configure axis
axis.PositionSet(0);
// set sample addresses
ulong userBuffer0Addr = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeUSER_BUFFER, 0);
ulong previousVelocityAddr = controller.AddressGet(RSIControllerAddressType.RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE, MB2);
ulong currentVelocityAddr = axis.AddressGet(RSIAxisAddressType.RSIAxisAddressTypeCOMMAND_VELOCITY);
// write 1 to user buffer index 0 for MB2 multiplication
controller.MemoryDoubleSet(userBuffer0Addr, 1);
// MathBlock 1 config: subtract current velocity - previous velocity
var mbConfig1 = controller.MathBlockConfigGet(MB1);
mbConfig1.Operation = SUBTRACT;
mbConfig1.InputAddress0 = currentVelocityAddr; // input0: current command velocity
mbConfig1.InputAddress1 = previousVelocityAddr; // input1: previous velocity (from 2nd MathBlock)
mbConfig1.InputDataType0 = DOUBLE;
mbConfig1.InputDataType1 = DOUBLE;
mbConfig1.ProcessDataType = DOUBLE;
// MathBlock 2 config: multiply current velocity by 1 to store previous velocity
var mbConfig2 = controller.MathBlockConfigGet(MB2);
mbConfig2.Operation = MULTIPLY;
mbConfig2.InputAddress0 = currentVelocityAddr; // input0: current command velocity
mbConfig2.InputAddress1 = userBuffer0Addr; // input1: constant "1" from user buffer
mbConfig2.InputDataType0 = DOUBLE;
mbConfig2.InputDataType1 = DOUBLE;
mbConfig2.ProcessDataType = DOUBLE;
// set MathBlock configurations
controller.MathBlockConfigSet(MB1, mbConfig1);
controller.MathBlockConfigSet(MB2, mbConfig2);
// wait 1 sample for MathBlock config to take effect
controller.SampleWait(1);
// move axis with small acceleration to verify MathBlock calculation
axis.MoveVelocity(VELOCITY, ACCELERATION);
controller.SampleWait(10);
// get latest sample velocity delta from MathBlock 1
double latestVelocityDelta = controller.MathBlockProcessValueGet(MB1).Double;
// reduce velocity back to 0
axis.MoveVelocity(0, ACCELERATION);
// get results
double sampleRate = controller.SampleRateGet();
double userUnits = axis.UserUnitsGet();
double calculatedAcceleration = latestVelocityDelta * Math.Pow(sampleRate, 2) / userUnits;
// rounding to 8 decimals matches encoder resolution for most systems.
// this is more precise than typical hardware needs.
double calculatedAccelerationRounded = Math.Round(calculatedAcceleration, 8);
// print results
Console.WriteLine($"Acceleration: {calculatedAccelerationRounded} (expected: {ACCELERATION})");
// verify accuracy
if (ACCELERATION != calculatedAccelerationRounded)
throw new Exception("❌ MathBlock result is outside accepted tolerance.");
double UserUnitsGet()
MathBlock operations.
Definition rsienums.h:1614
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
