Represents a collection of joints in Cartesian space with forward and inverse kinematics. This class provides an interface for 3D Path motion for any actuator, whether it be an articulated arm, a linear gantry, or a custom robot. Use Robot Creation Methods to make one using a MotionController, MultiAxis and a kinematic model. Visit the Path Motion or G-Code for more information on how to use the Robot class. More...
Static Functions
static RobotRobotCreate (MotionController *controller, MultiAxis *multiAxis, KinematicModelBuilder *builder, uint32_t motionFrameBufferSize=MotionFrameBufferSizeDefault)
static RobotRobotCreate (MotionController *controller, MultiAxis *multiAxis, const char *const modelIdentifier, uint32_t motionFrameBufferSize=MotionFrameBufferSizeDefault)
static void RobotDelete (MotionController *controller, Robot *robot)
 Delete a Robot.
Functions
PathState PathStateGet ()=0
 Gets the path state of the Robot.
bool PathStateWait (PathState stateWaitFor, uint64_t timeoutMilliseconds)=0
 Waits for a specific path state.
bool PathStateWaitChange (PathState stateWaitChange, uint64_t timeoutMilliseconds)=0
 Waits for the path state to not be the specified state.
uint64_t MotionCounterGet ()=0
 Gets the current motion counter of the Robot.
void MotionCounterWait (uint64_t motionCount, uint64_t timeoutMilliseconds)=0
 Waits for the counter increment by the specified amount.
uint64_t SampleCounterGet ()=0
 Gets the current sample counter of the Robot's main execution thread.
void SampleCounterWait (uint64_t sampleCount, uint64_t timeoutMilliseconds)=0
 Waits for the sample counter of the Robot's main execution thread to incremented by the specified amount.
bool IsRunning ()=0
 Returns whether or not the robot is in motion (from executor or other source). Can be used to determine if safe to command a new move.
bool PathIsRunning ()=0
 Returns whether or not a planned path is being executed. All G-Code gets converted to path. Joint moves aren't path moves.
bool MotionDoneGet ()=0
uint64_t MotionDoneWait (uint64_t timeoutMilliseconds=TimeoutForever)=0
bool HasError ()=0
 Get the error state of the underlying Trajectory Executor.
const char *const ErrorMessageGet ()=0
 Get the text of any error in the Trajectory Executor.
void Resume ()=0
 Resume an axis.
void Stop ()=0
 Stop an axis.
void EStopAbort ()=0
 E-Stop, then abort an axis.
void Abort ()=0
int32_t AmpEnableSet (bool enable, int32_t ampActiveTimeoutMilliseconds=RapidCodeMotion::AmpEnableTimeoutMillisecondsDefault, bool overrideRestrictedState=false)=0
void EStop ()=0
void ClearFaults ()=0
Pose ActualPoseGet (LinearUnits units=LinearUnits::None)=0
 Get the current actual pose of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
RobotPosition ActualPositionGet (LinearUnits units=LinearUnits::None)=0
 Get the current actual position of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
Pose CommandPoseGet (LinearUnits units=LinearUnits::None)=0
 Get the current commanded pose of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
RobotPosition CommandPositionGet (LinearUnits units=LinearUnits::None)=0
 Get the current commanded position of the robot from the trajectory executor in the specified units. If no units are specified, the Robot's model units are used. The rotation/orientation is stored as a quaternion, so units are not applicable. If you want to get the Euler angles of the orientation then you can use ToEuler(), which will return a Vector3d with the Euler angles in the specified units.
RapidVector< double > JointsActualPositionsGet ()=0
 Get the actual positions of the axes in the underlying MultiAxis.
RapidVector< double > JointsCommandPositionsGet ()=0
 Get the commanded positions of the axes in the underlying MultiAxis.
RapidVector< double > InverseKinematics (Pose pose)=0
 Run the given pose through the current inverse kinematic model to see the joint positions the robot would choose.
RapidVector< double > InverseKinematics (RobotPosition pose)=0
Pose ForwardKinematics (const RapidVector< double > &joints)=0
 Get the Actual pose of the robot from the the joint MultiAxis positions.
RobotPosition ForwardKinematicsPosition (const RapidVector< double > &joints)=0
 Get the Actual position of the robot from the the joint MultiAxis positions.
const KinematicModelModelGet ()=0
void EndEffectorTransformSet (const Pose &transform)=0
 Transform that defines the control point relative to the end end of the current kinematic model For example if you have a suction cup EoAT that is 0.15 meters from the mounting point of your robotic arm you could call this method with Pose(0,0,.15) to define the tool z offset.
void EndEffectorTransformSet (const RobotPosition &transformPosition)=0
 Transform that defines the control point relative to the end end of the current kinematic model with a RobotPosition.
void OriginTransformSet (const Pose &transform)=0
 Transform that defines the origin of the robot in the world. For example if you have a gantry that is homed but what the command MoveAbsolute(0,0,0) to put you at 4 in the x axis, you could call this method with Pose(4,0,0).
void OriginTransformSet (const RobotPosition &transformPosition)=0
 Transform that defines the origin of the robot in the world as a RobotPosition.
const RobotPositionEndEffectorTransformGet ()=0
 End of Robot to TCP.
const RobotPositionOriginTransformGet ()=0
 Offset for the origin location.
const double ScaleFactorBetweenUnitsGet (LinearUnits from, LinearUnits to)=0
 Gets scaling for scale factor needed to convert from -> to units by multiplying.
const double ScaleFactorBetweenUnitsGet (RotationalUnits from, RotationalUnits to)=0
void MoveAbsolute (const Pose &absolutePose)=0
 Executes a point-to-point absolute motion in cartesian space.
void MoveRelative (const Pose &relativePose)=0
 Executes a point-to-point motion relative to the current end effector Pose.
void PathClear ()=0
 Clears out all loaded lines and arcs from the path. Part of the PathMotion method group.
void PathVelocitySet (double unitsPerSecond)=0
 Sets the target linear cartesian velocity for each move (UserUnits/second).
double PathVelocityGet ()=0
 Gets the target velocity for the machine (UserUnits/second).
void PathAccelerationSet (double unitsPerSecondSquared)=0
 Sets the target acceleration for the machine (UserUnits/second^2). Should be set appropriately based on your hardware.
double PathAccelerationGet ()=0
 Gets the target acceleration for the machine (UserUnits/second^2).
void PathProgrammingModeSet (PathMode mode)=0
 Sets the programming mode (Relative/Absolute).
PathMode PathProgrammingModeGet ()=0
 Gets the programming mode (Relative/Absolute).
void PathArc (const Pose &target, double radius, RotationDirection direction)=0
 Appends an arc on to the current on the PathPlaneGet() plane XY by default.
void PathArc (const RobotPosition &target, double radius, RotationDirection direction)=0
void PathArc (const Pose &target, const Vector3d &center, RotationDirection direction)=0
 Appends an arc on to the current path with end pose about a specific center point.
void PathArc (const RobotPosition &RobotPosition, const Vector3d &center, RotationDirection direction)=0
void PathLine (const Pose &target)=0
void PathLine (const RobotPosition &position)=0
void PathPlaneSet (Plane plane)=0
 Sets the plane for the purposes of ambiguous cases (arcs >= 180deg). Last set plane or XY plane is default.
Plane PathPlaneGet ()=0
 Gets the plane some arcs will be forced to be on.
void PathLinearScalingSet (double scaleFactor)=0
 Sets scaling between the input to path motion and output of path motion to the kinematic model.
double PathLinearScalingGet () const =0
 Gets scaling between input to path motion and output of path motion to the kinematic model.
void PathUnitsSet (LinearUnits units)=0
 Defines the units Cartesian Path Motion is in.
LinearUnits PathUnitsGet () const =0
 Gets the units of path motion.
double PathProcessLoadedMoves ()=0
 Processes our loaded moves. Used internally and to check whether loaded moves are valid, and must be called before both PathPlannedPositionsGet and PathDurationGet.
RapidVector< RobotPositionPathPlannedPositionsGet (uint64_t startFrame, uint64_t frameCount)=0
 Get Positions (see RobotPosition) representing the planned motion in cartesian space that will happen when run is called.
double PathDurationGet ()=0
 Get total (seconds) duration of the planned motion that will happen when run is called.
void Run ()=0
 Run the loaded path lines/arcs. The behavior is non-blocking. Use Robot.MotionDoneWait() to block.
uint32_t MotionFrameBufferSizeGet ()=0
 Gets the TrajectoryExecutor's buffer size in frames, one frame is used per RMP sample period.
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t NumberGet ()
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Attributes
RSI::RapidCode::Cartesian::GcodeGcode
 An object to load and run Gcode files.
Static Attributes
static constexpr uint64_t TimeoutForever = 0xFFFFFFFFFFFFFFFF
 Use this 64-bit value to wait forever in methods which accept a timeoutMilliseconds parameter.
static constexpr uint32_t MotionFrameBufferSizeDefault = 256
 The default size the Robot's trajectory executor buffer. There is one frame per RMP sample period.
static constexpr uint32_t MotionFrameBufferSizeMinimum = 50
 The minimum size allowable for the Robot's trajectory executor buffer.
Description
Definition at line 812 of file cartesianrobot.h.
