axis-config-ampfault.cs
Console.WriteLine("📜 Axis Config: AmpFault");
// set
axis.AmpEnableSet(false); // disable the amp
axis.AmpFaultActionSet(RSIAction.RSIActionABORT); // set the action that will occur when there is an amp fault.
axis.AmpFaultTriggerStateSet(false); // set the state of the amp fault.
axis.AmpFaultDurationSet(1); // set the duration (seconds) required before the Amp Fault event triggers.
// get
bool isEnabled = axis.AmpEnableGet();
RSIAction faultAction = axis.AmpFaultActionGet();
bool faultTriggerState = axis.AmpFaultTriggerStateGet();
double faultDuration = axis.AmpFaultDurationGet();
Console.WriteLine($"Amp Enabled: {isEnabled}");
Console.WriteLine($"Fault Action: {faultAction}");
Console.WriteLine($"Fault Trigger State: {faultTriggerState}");
Console.WriteLine($"Fault Duration: {faultDuration}");
RSIAction AmpFaultActionGet()
Get the Amp Fault action.
bool AmpEnableGet()
Set the Amp Fault action.
double AmpFaultDurationGet()
Definition rsienums.h:1256
