error-logs.cs
See Monitoring: Error Logging 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to read RsiError objects from the error log.
It shows how to turn off exceptions, perform operations that generate errors,
and then read and display error messages from the error log.
Console.WriteLine("📜 Error Logs");
// turn exceptions off (errors will be logged as RsiError objects)
controller.ThrowExceptions(false);
axis.ThrowExceptions(false);
// cause an errors
controller.RecorderStart(); // recorder count is zero
axis.MoveVelocity(0.0, 0.0); // zero acceleration
// print error count
var controllerErrorCount = controller.ErrorLogCountGet();
var axisErrorCount = axis.ErrorLogCountGet();
Console.WriteLine($"Controller error count: {controllerErrorCount} (expected: 1)");
Console.WriteLine($"Axis error count: {axisErrorCount} (expected: 1)");
// print controller errors
while(controller.ErrorLogCountGet() > 0)
// ErrorLogGet retrieves and removes the next error from the log
RsiError error = controller.ErrorLogGet();
Console.WriteLine($" Controller Error: {error.Message}");
// print axis errors
while( axis.ErrorLogCountGet() > 0)
RsiError error = axis.ErrorLogGet();
Console.WriteLine($" Axis Error: {error.Message}");
// print error count after reading logs
Console.WriteLine($"Controller error count: {controller.ErrorLogCountGet()} (expected: 0)");
Console.WriteLine($"Axis error count: {axis.ErrorLogCountGet()} (expected: 0)");
// verify error count
if (controllerErrorCount < 1 || axisErrorCount < 1)
throw new Exception("❌ Error log did not record expected errors.");
int32_t ErrorLogCountGet()
Definition rsi.h:111
