UpdateBufferPoints.cpp
#include <cassert>
#include <cmath>
#include "SampleApps.h"
int UpdateBufferPoints::Run()
/* CONSTANTS */
const int AXIS_COUNT = 1; // number of axes
const int AXIS_NUMBER = 0; // axis number
const double USER_UNITS = 1048576; // counts per unit / user units (set as appropiate)
// Motion parameters
const double TIME_SLICE = 0.001; // 0.001s = 1ms
const int REVS = 2; // number of revolutions
const int RPS = 1; // revs / sec
const int TOTAL_POINTS = (int)(REVS / TIME_SLICE / RPS); // total number of points
const int BUFFER_SZ = 100; // Number of points to send in a buffer
const int EMPTY_CT = 10; // Number of points that remains in the beffer before an e-stop
USE_HARDWARE = false;
/* SAMPLE APP BODY */
// Initizalize the controller from software w/ multiple axes
if (USE_HARDWARE)
MultiAxis* multiAxis;
// add an additional axis for the multiaxis supervisor
controller->MotionCountSet(AXIS_COUNT + 1);
// create the multiaxis using the ID of the first free axis (0 indexed)
multiAxis = controller->MultiAxisGet(AXIS_COUNT);
// Get the axis and configure it
axis->PositionSet(0); // Make sure motor starts at position 0 everytime.
axis->UserUnitsSet(USER_UNITS); // Change your user units.
multiAxis->AxisAdd(axis); // Add the axis to the multiaxis supervisor
// populate the positions and times
std::vector<double> positions, times;
for (int i = 0; i < TOTAL_POINTS; i += AXIS_COUNT)
positions.push_back(i * TIME_SLICE * RPS);
times.push_back(TIME_SLICE);
// prepare the controller (and drive)
multiAxis->Abort();
multiAxis->ClearFaults();
assert(multiAxis->StateGet() == RSIState::RSIStateIDLE);
multiAxis->AmpEnableSet(true);
// reset the motion ID to 0
multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0], &times[0], 1, -1, false, true);
multiAxis->MotionIdSet(0);
// Establish how to keep track of what blocks have been sent
int curMotionElementID = 0, curMotionID = 0, finalMotionID = 0;
int numPointsToSend = BUFFER_SZ;
int endOfLastSent = 0;
bool exitCondition = false;
// Set up a motion hold gate so we can start buffering blocks
const int motionHoldGate = 3;
controller->MotionHoldGateSet(motionHoldGate, true);
multiAxis->MotionHoldGateSet(motionHoldGate);
for (int i = 0; i < 2; ++i)
multiAxis->MovePT(RSIMotionType::RSIMotionTypePT, &positions[0] + endOfLastSent * AXIS_COUNT, &times[0] + endOfLastSent, numPointsToSend, EMPTY_CT, false, exitCondition);
endOfLastSent += numPointsToSend;
++finalMotionID;
// Set up the interrupt frequency period
controller->SyncInterruptPeriodSet(10); // this generates an interrupt every x cycles of a 1KHz sample rate
// With our timeslices of 1ms, this is 10*1ms=10ms
controller->MotionHoldGateSet(motionHoldGate, false); // release the hold gate to start moving
while (!exitCondition)
int32_t sampleRecieved = controller->SyncInterruptWait(); // see above for timing
curMotionID = multiAxis->MotionIdExecutingGet(); // this takes an unspecified amount of time (non-rtos) so this is going to be called sometime after the interrupt gets handled.
// There's an additional delay to retrieve the data as well.
curMotionElementID = multiAxis->MotionElementIdExecutingGet();
Each MovePT assigns a new MotionID for each call to a move update (with the bufferred points)
Working under the assumption that each Buffer gets a new ID, send two (or several) smaller ones
and when the change in IDs is greater than some number, send a new one
// change this logic to manage the number of buffered moves (and points) as appropiate
// generate points as appropiate
if (std::abs(finalMotionID - curMotionID) < 2)
// check end condition
if (TOTAL_POINTS <= (endOfLastSent + BUFFER_SZ))
numPointsToSend = TOTAL_POINTS - endOfLastSent; // send the remaining points
exitCondition = true;
printf("MotionID %d\nEnd of Last Sent %d\nElement ID %d\nNum to Send %d\nIs Done %s\n===========================================\n\n",
curMotionID, endOfLastSent, curMotionElementID, numPointsToSend, exitCondition ? "yes" : "no");
++finalMotionID;
printf("Updates Done. Waiting to finish motion.\n");
multiAxis->MotionDoneWait();
printf("Motion Complete. Final Motion ID: %d\tFinal Element ID %d\n", multiAxis->MotionIdExecutingGet(), multiAxis->MotionElementIdExecutingGet());
multiAxis->EStopAbort();
catch (RsiError const& err) {
printf("\n%s\n", err.text);
return -1;
controller->Delete();
return 0;
uint16_t MotionElementIdExecutingGet()
void AxisAdd(Axis *axis)
Definition rsi.h:12226
void MotionIdSet(uint16_t id)
Set the Motion identifier.
RSIState StateGet()
void MotionHoldGateSet(bool hold)
Set the Motion Hold Gate.
void EStopAbort()
E-Stop, then abort an axis.
Definition rsi.h:111
@ RSIMotionTypePT
Definition rsienums.h:1180
@ RSIActionNONE
Definition rsienums.h:1257
@ RSIStateIDLE
Idle, ready for anything.
Definition rsienums.h:1016
