rttaskglobals.h
See Real-Time Tasks 📜 for a detailed explanation of this sample code.
#pragma once
#ifndef RT_TASKS_GLOBALS_H
#define RT_TASKS_GLOBALS_H
#include <atomic> // For std::atomic
#include <cstddef> // For std::size_t, offsetof
#include <cstring> // For std::memset, std::strcmp
#include <type_traits> // For std::is_same
#include "rttask.h"
#if defined(WIN32)
#define LIBRARY_EXPORT __declspec(dllexport)
#define LIBRARY_IMPORT __declspec(dllimport)
#elif defined(__linux__)
#define LIBRARY_EXPORT __attribute__((visibility("default")))
#define LIBRARY_IMPORT __attribute__((visibility("default")))
#else
#endif // defined(WIN32) || defined(__linux__)
#define NAME(name) name
#define CONCAT(left, right) left ## right
#define RSI_TASK(name) \
void CONCAT(name, Core)(RSI::RapidCode::RealTimeTasks::GlobalData*); \
extern "C" LIBRARY_EXPORT int32_t NAME(name)(RSI::RapidCode::RealTimeTasks::GlobalData* data, char* buffer, const uint32_t size) { return CallFunction(CONCAT(name, Core), data, buffer, size); } \
void CONCAT(name, Core)(RSI::RapidCode::RealTimeTasks::GlobalData* data)
template<typename FunctionType>
int32_t CallFunction(FunctionType&& func, RSI::RapidCode::RealTimeTasks::GlobalData* data, char* buffer, const uint32_t size)
int32_t result = 0;
func(data);
catch(const std::exception& error)
result = -1;
std::snprintf(buffer, size, "%s", error.what());
catch(...)
result = -1;
std::snprintf(buffer, size, "Unknown error occurred in task.");
return result;
namespace RSI
namespace RapidCode
namespace RealTimeTasks
// Add global variables as data members of this struct using the RSI_GLOBAL macro.
// Please use "plain-old data" types (POD), preferably sized ones, such as:
// int32_t, uint32_t,
// int64_t, uint64_t,
// float, double,
// char, bool,
// Arrays of POD types are technically possible, but it will be difficult to access them from the RapidCode API.
struct GlobalData
GlobalData() { std::memset(this, 0, sizeof(*this)); }
GlobalData(GlobalData&& other) { std::memcpy(this, &other, sizeof(*this)); }
// A shared integer counter
RSI_GLOBAL(int64_t, counter);
// Shared values for FollowSensor
RSI_GLOBAL(int32_t, startingSample);
RSI_GLOBAL(double, sensorValue);
inline constexpr GlobalMetadataMap<RSI::RapidCode::RealTimeTasks::GlobalMaxSize> GlobalMetadata(
REGISTER_GLOBAL(counter),
REGISTER_GLOBAL(startingSample),
REGISTER_GLOBAL(sensorValue),
extern "C"
LIBRARY_EXPORT int32_t GlobalMemberOffsetGet(const char* const name)
return GlobalMetadata[name].offset;
static_assert(std::is_same<decltype(&GlobalMemberOffsetGet), GlobalMemberOffsetGetter>::value, "GlobalMemberOffsetGet function signature does not match GlobalMemberOffsetGetter type.");
LIBRARY_EXPORT int32_t GlobalNamesFill(const char* names[], int32_t capacity)
int32_t index = 0;
for (; index < GlobalMetadata.Size() && index < capacity; ++index)
names[index] = GlobalMetadata[index].key;
return index;
static_assert(std::is_same<decltype(&GlobalNamesFill), GlobalNamesGetter>::value, "GlobalNamesGet function signature does not match GlobalNamesGetter type.");
LIBRARY_EXPORT std::int32_t GlobalMemberTypeGet(const char* const name)
return static_cast<std::int32_t>(GlobalMetadata[name].type);
static_assert(std::is_same<decltype(&GlobalMemberTypeGet), GlobalMemberTypeGetter>::value, "GlobalMemberTypeGet function signature does not match GlobalMemberTypeGetter type.");
static_assert(sizeof(GlobalData) <= RSI::RapidCode::RealTimeTasks::GlobalMaxSize, "GlobalData struct is too large.");
} // end namespace RealTimeTasks
} // end namespace RapidCode
} // end namespace RSI
extern "C"
LIBRARY_IMPORT RSI::RapidCode::MotionController* MotionControllerGet(char* errorBuffer, const uint32_t errorBufferSize);
LIBRARY_IMPORT RSI::RapidCode::Axis* AxisGet(const int32_t axisIndex, char* errorBuffer, const uint32_t errorBufferSize);
LIBRARY_IMPORT RSI::RapidCode::RapidCodeNetworkNode* NetworkNodeGet(const int32_t index, char* errorBuffer, const uint32_t errorBufferSize);
LIBRARY_IMPORT RSI::RapidCode::MultiAxis* MultiAxisLoad(const int32_t motionSupervisorIndex, char* errorBuffer, const uint32_t errorBufferSize);
template<typename FunctionType, typename ... Args>
auto RTObjectGet(FunctionType&& func, Args&& ... args)
char errorBuffer[256] = {};
auto object = std::forward<FunctionType>(func)(std::forward<Args>(args)..., errorBuffer, sizeof(errorBuffer));
if (object == nullptr) { throw std::runtime_error(errorBuffer); };
return object;
inline auto RTMotionControllerGet() { return RTObjectGet(MotionControllerGet); }
inline auto RTAxisGet(const int32_t index) { return RTObjectGet(AxisGet, index); }
inline auto RTMultiAxisLoad(const int32_t motionSupervisorIndex) { return RTObjectGet(MultiAxisLoad, motionSupervisorIndex); }
inline auto RTNetworkNodeGet(const int32_t index) { return RTObjectGet(NetworkNodeGet, index); }
#endif // !defined(RT_TASKS_GLOBALS_H)
Definition rsi.h:12226
LIBRARY_EXPORT int32_t GlobalMemberOffsetGet(const char *const name)
@[RTTasksGlobalData]
