path-3d-points.cs
See Motion: Path 📜 for a detailed explanation of this sample code.
/* This sample demonstrates how to get 3D path points for rendering visualization.
Shows how to retrieve planned positions from a Robot path for use with 3D graphics libraries
or visualization tools.
Console.WriteLine("📜 Motion: Path 3D Rendering");
// set robot axis labels
// get the 3 axis needed for XYZ robot
Helpers.CheckErrors(xAxis);
Helpers.CheckErrors(yAxis);
Axis zAxis = controller.AxisGet(Constants.AXIS_2_INDEX);
Helpers.CheckErrors(zAxis);
// configure phantom axes
Helpers.PhantomAxisReset(zAxis);
// set axis labels
xAxis.UserLabelSet(xLabel);
yAxis.UserLabelSet(yLabel);
zAxis.UserLabelSet(zLabel);
// create multi-axis object for joints
int multiAxisMotionSupervisorIndex = controller.AxisCountGet(); // MultiAxis supervisor indices begin after Axis supervisor indices
Axis[] axes = [xAxis, yAxis, zAxis];
// create simple 3-axis kinematic model
const string modelName = "RSI_XYZ";
const double scaling = 1.0;
const double offset = 0.0;
builder.UnitsSet(LinearUnits.Millimeters);
// create Robot object
Robot robot = Robot.RobotCreate(controller, jointsMultiAxis, builder, MotionController.AxisFrameBufferSizeDefault);
Helpers.CheckErrors(robot);
// set path motion parameters
robot.PathAccelerationSet(100);
robot.PathVelocitySet(50);
// program path motion
robot.PathProgrammingModeSet(PathMode.Absolute);
robot.PathLine(target: new Pose(1, 1, 1));
robot.PathArc(
target: new Pose(0, 2, 1),
center: new Vector3d(0, 1, 1),
direction: RotationDirection.Clockwise);
// process the path to build trajectory
robot.PathProcessLoadedMoves();
// get path points for 3D rendering
Console.WriteLine("Retrieving 3D path points for rendering:");
const ulong frameCount = 500;
ulong startFrame = 0;
int totalPointCount = 0;
ulong retrievedFrames;
do
RapidVectorRobotPosition positions = robot.PathPlannedPositionsGet(startFrame, frameCount);
retrievedFrames = positions.Size();
foreach (RobotPosition position in positions.ToArray())
Vector3d spatial = position.Pose.Position;
// print every 100th point as an example
if (totalPointCount % 100 == 0)
Console.WriteLine($"Point {totalPointCount,3}: X={spatial.X,5:F2}, Y={spatial.Y,5:F2}, Z={spatial.Z,5:F2}");
totalPointCount++;
// add code here to create rendering with your preferred 3D library
// examples:
// vector3 = new Vector3D(spatial.X, spatial.Y, spatial.Z);
// linePositions.Add(vector3);
// scene.AddPoint(spatial.X, spatial.Y, spatial.Z);
startFrame += retrievedFrames;
while (retrievedFrames == frameCount);
// print total points retrieved
Console.WriteLine($"Total 3D points retrieved: {totalPointCount}");
jointsMultiAxis.AxisRemoveAll();
const int AXIS_1_INDEX
Definition _constants.cs:21
const int AXIS_2_INDEX
Default: 2.
Definition _constants.cs:22
Definition rsi.h:860
void AxisRemoveAll()
Definition rsi.h:12226
