_setup.cs
Console.WriteLine("📜 Sample Apps Setup");
// start fresh each time
Config.KillExistingController();
// create new controller
var creationParams = Config.GetCreationParameters();
MotionController controller = MotionController.Create(creationParams);
// setup controller
// print setup
Console.WriteLine($"RMP path: {creationParams.RmpPath}");
Console.WriteLine($"Use hardware: {Constants.USE_HARDWARE}");
Console.WriteLine($"Axis count: {controller.AxisCountGet()}");
Console.WriteLine($"MultiAxis count: {controller.MotionCountGet() - controller.AxisCountGet()}");
for (int i = 0; i < Constants.AXIS_COUNT; i++)
Axis? currentAxis = controller.AxisGet(axisNumber: Constants.AXIS_INDICES[i]);
Helpers.CheckErrors(currentAxis);
// set userunits
currentAxis.UserUnitsSet(countsPerUserUnit: Constants.AXIS_USER_UNITS[i]);
// print axis info
if (currentAxis != null)
Console.WriteLine($" Axis {i}: Motor Type = {currentAxis.MotorTypeGet()}");
Console.WriteLine($" Axis {i}: UserUnits = {currentAxis.UserUnitsGet()}");
Console.WriteLine($"❌ Setup Error: {e.Message}");
const int MULTIAXIS_COUNT
Definition _constants.cs:15
const int AXIS_COUNT
Default: 6.
Definition _constants.cs:14
This namespace provides static methods and constants for user configuration in RMP applications....
Definition config.h:25
